ISO mini v gantry plate for 2040
Discussion in 'Share Parts' started by Masao, May 8, 2017.
  1. Masao
    Masao New
    Does anyone has sketchup model for the mini v gantry plate to be used on 2040 v-slot rail? I was going to use 2020 mini v gantry plate but I need the v-wheels to be able to ride on 2040 rails.
  2. Masao
    Masao New
    Here is the model for the 2040 mini v plate. I designed using the Designspark Mechanical and exported to Sketchup.
    Nat972 likes this.
  3. Masao
    Masao New
    Few more images.
  4. Masao
    Masao New
    Thanks, I'm thinking about using as X gantry plate to house my CO2 laser focus head. I wanted to keep it compact so that I get maximum movement on X axis travel.
  5. crispin
    crispin New
    Yeah! Add a 3rd hole between the existing pairs for an additional *centered* belt-attachment option.
  6. Masao
    Masao New
    Here are versions with centered belt attachment.
    ArrArr, crispin and Grantman like this.
  7. 3DPDude
    3DPDude New
    Hi;
    thanks for designing this!!!! I have a q tho: why are two holes larger than the other two?
    Thanks!!
  8. Giarc
    Eccentric spacers need the larger holes.
  9. 3DPDude
    3DPDude New
    Thanks!!!
    what are the dimensions of this part?
  10. tulayha
    tulayha New
    Hi, a couple years late but could someone provide any other format then sketchup? i cant find any models for a 2040 plate anywhere else
