Grbl?
Discussion in 'General Talk' started by khuff, Feb 17, 2018.
  1. khuff
    khuff New
    I am finished with my build but i am having trouble seeing the settings in the grbl panel
    it connects to the board but doesn't show a firmware version or any settings.
    when i hit get grbl settings nothing happens.i have tried it on two different machines with the same results
    CNC xPRO V3 Controller Stepper Driver thanks in advance for any help or comments
  2. khuff
    khuff New
    i found the issue the com port was set incorrectly
    Thank You
  3. Jesse Mccabe
    what settings worked for you same issue
  4. Jurgita
    Jurgita New
    Hello, i am beginner (i have a laser for a few days) and have some problems, maybe you know what caused it (that brown background)?
    That just looks like travel moves between cuts. If your laser also turns on for the brown sections, you likely don't have Laser Mode correctly enabled: See Grbl v1.1 Laser Mode · gnea/grbl Wiki
    Jurgita likes this.
  6. Jurgita
    Jurgita New
    Thak you very much!
