7050 Sphinx
Discussion in 'CNC Mills/Routers' started by Michael.M, Jul 15, 2017.
  1. Michael.M
    Michael.M Veteran
    Hey guys one VERY important thing to keep in mind while milling aluminum is to keep the chips away from the vwheels as much as possible. I have done some light milling and had no problems but recently I milled a bunch of 1/2" aluminum plates and my entire machine was covered in chips. I attempted to brush & vaccum them away from the wheel tracks but sadly I ruined some of the wheels. :-(
    The chips became embedded in the wheels themselves. I use an air blast system to clear chips from the cut so a pemanent vac system that doesn't interfere with this would be necessary.
  2. Michael.M
    Michael.M Veteran
    Loc Line makes some pretty good looking vaccum systems that may not interfere...
  3. mortorojo
    mortorojo New
    Michael.M likes this.
  4. NeeqOne
    NeeqOne Well-Known
  5. mortorojo
    mortorojo New
    These are not my sensors, I just designed some mounts to use on my CNC. Im not into selling these either. If you don't have a 3d printer I would check out Shapeways.com, you can upload the files and pick the material.
  6. gary bergin
    what size is your aluminum bed (thickness)?
