X Pro V3 boot error - fixed
Discussion in 'Controller Boards' started by Dr.O, Apr 1, 2018.
  1. Dr.O
    Dr.O New
    Hi guys!
    I'm building my first OX CNC, today I've started to wire electronics and straight away got stuck
    When I connect my XProV3 controller to Mac, I get next messages:
    These messages are cycled and xpro won't boot
  2. Dr.O
    Dr.O New
    there is oulput logs in ugs platform
    **** Connected to /dev/tty.usbserial-DN03VVBC @ 115200 baud ****
    Grbl 1.1f ['$' for help]
    $0 = 10 (Step pulse time, microseconds)
    $1 = 255 (Step idle delay, milliseconds)
    $2 = 0 (Step pulse invert, mask)
    $3 = 6 (Step direction invert, mask)
    $4 = 1 (Invert step enable pin, boolean)
    $5 = 0 (Invert limit pins, boolean)
    $6 = 0 (Invert probe pin, boolean)
    $10 = 1 (Status report options, mask)
    $11 = 0.020 (Junction deviation, millimeters)
    $12 = 0.002 (Arc tolerance, millimeters)
    $13 = 0 (Report in inches, boolean)
    $20 = 0 (Soft limits enable, boolean)
    $21 = 0 (Hard limits enable, boolean)
    $22 = 0 (Homing cycle enable, boolean)
    $23 = 1 (Homing direction invert, mask)
    $24 = 25.000 (Homing locate feed rate, mm/min)
    $25 = 500.000 (Homing search seek rate, mm/min)
    $26 = 250 (Homing switch debounce delay, milliseconds)
    $27 = 1.000 (Homing switch pull-off distance, millimeters)
    $30 = 1000 (Maximum spindle speed, RPM)
    $31 = 0 (Minimum spindle speed, RPM)
    $32 = 0 (Laser-mode enable, boolean)
    $100 = 26.667 (X-axis travel resolution, step/mm)
    $101 = 26.667 (Y-axis travel resolution, step/mm)
    $102 = 200.000 (Z-axis travel resolution, step/mm)
    $110 = 2500.000 (X-axis maximum rate, mm/min)
    $111 = 2500.000 (Y-axis maximum rate, mm/min)
    $112 = 2500.000 (Z-axis maximum rate, mm/min)
    $120 = 50.000 (X-axis acceleration, mm/sec^2)
    $121 = 50.000 (Y-axis acceleration, mm/sec^2)
    $122 = 50.000 (Z-axis acceleration, mm/sec^2)
    $130 = 320.000 (X-axis maximum travel, millimeters)
    $131 = 525.000 (Y-axis maximum travel, millimeters)
    $132 = 68.000 (Z-axis maximum travel, millimeters)
    ok
    >>> $G
    An error was detected while sending '$G': (error:2) Missing the expected G-code word value or numeric value format is not valid. Streaming has been paused.
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100>
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0>
    Error while processing response <error:11>: Index: 0, Size: 0
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:102,100,100>
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:103,100,100>
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:105,100,90>
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:107,100,90>
    Error while processing response <error:1>: Index: 0, Size: 0
    Error while processing response <error:2>: Index: 0, Size: 0
    [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,90>
  3. Dr.O
    Dr.O New
    by the way
    when i use serial monitor in arduino envirement i don't get ane errors an i can use $ and $$ commands nd change variables
  4. Dr.O
    Dr.O New
    Checked on Windows 10
    It's working without any errors
    I've noticed in logs that UGS doesn't see java, might be it would help if I fix java problem
  5. Dr.O
    Dr.O New
    Fixed by cleaning leftovers and reinstalling drivers
