BF3D OX (Big Freakin' 3D OX)
Discussion in '3D printers' started by Bud Griffin, Jun 3, 2017.
  1. Bud Griffin
    Bud Griffin published a new build:
  2. Bud Griffin
    Actually both extruders will have access to the entire build area. Only the extruder in use at the time will be in the build area. Each extruder will park itself on it's respective side of the printer. ReprapFirmware on the Duetwifi takes care of all the control of the extruders position based on the sliced model. Slic3r is able to slice a model to take advantage of multiple extruders.
    From the Duet website on configuring multiple X axis:
    Of course the true test will be in getting it all configured. But then where's the fun in it being simple.
  3. stephen cia
    stephen cia Well-Known
    Does each toolhead have their own grid mapping for bed mesh?
  4. Bud Griffin
  5. William Honeycutt
    Are the two z axis “towers” steady without a piece across the top?
  6. Ronald Neely
    Where did you get your closed loop belt for your Z axis?? I have a similar build and cannot find the 2GT 2mm in the closed loop size I need. I need a 1710mm closed loop.
  7. stephen cia
  8. Ronald Neely
    What size are you running?
  9. Ronald Neely
    thanks for the website.
