ZideX
Discussion in '3D printers' started by stephen cia, Jun 30, 2017.
  1. cmwwebfx
    cmwwebfx New
    You have done well mate. Merry Christmas to you and the family.
  2. Cncpro
    Cncpro New
    Merry Christmas to everyone and their families.
  3. stephen cia
    stephen cia Well-Known
    Woohoo big day today. Success dual print with no tower and or shield whatsoever!
  4. cmwwebfx
    cmwwebfx New
    Maaaaan... You are killing me. I want to build this asap. Nice work my friend.
  5. stephen cia
    #65 stephen cia, Jan 11, 2018
  6. stephen cia
    maker muse tolerance test. slightly modified to make it dual extrusion. 0.5, 0.4, and 0.3 moves :) other smaller gaps stuck tight
    I really like plugging the nozzle more than I thought. no need for purge bucket, ooze shield and or prime tower.
    Cncpro likes this.
  7. cmwwebfx
    cmwwebfx New
    Stephen, what are the two silver strips at the front of the build plate? It looks like they are going under the front idler pulleys.
  8. biscuitlad
    Clips that go under the nozzles to stop oozes.
  9. stephen cia
    Sorry I thought I posted the video of it printing somewhere here....
    Here you go
  10. cmwwebfx
    cmwwebfx New
    Ahh I see. That is pretty cool. Did you print your parts in PLA+, PETG or ABS?
  11. stephen cia
    I use matterhacker PLA pro filament for all my parts. Works great
  12. biscuitlad
    It's impressive, for sure. I guess you had to double up with your supports for each extruder (top draw kit, BTW!), in order to get the stiffness, but doesn't that limit your bed size?
    I'm puzzled by this machine. I still don't understand why you didn't want to go with a core XY or prusa style frame for an IDEX printer, especially a direct drive model. I don't mean this as a criticism, it's just a bit unusual!
  13. cmwwebfx
    cmwwebfx New
    I love unusual. It breaks the mold of typical.
  14. biscuitlad
    Well, there's a reason that the typical wheel is round...
  15. Cncpro
    Cncpro New
    Great job! :thumbsup:
  16. stephen cia
    Regarding bed size, the current build has practical printable area of 118x118 mm square and I've managed to cram in 2 separate heads with very tight tolerance. Couldn't fit a finger between the two. The primary reason why the bed is small is because this all started as an experimental project, and so small is more practical to build and I was able to make sure x y z is mechanically aligned without tramming or compensation ( it actually feels good that way :)
    To make prusa machine an Idex, you will need to sacrifice build area in the x direction for the added space to park the second toolhead. The toolheads on my machine runs parallel so they will never crashed with each other.
    Also I love crane style printer but none out there has more than 1 head so I believe this project might be the first? :)
  17. stephen cia
    Dual draudi :) not perfect yet. I still need to figure out how to increase filament flow during initial small island hopping... Small areas golden scale wasn't printing correctly. But overall itst actually pretty good. And print were completed slightly less than 5hrs
    biscuitlad likes this.
  18. biscuitlad
    I think you can be fairly sure you are the first crane frame IDEX printer. Great work!
    stephen cia likes this.
  19. stephen cia
    fresh print! 140 micron 7hr 29min
    Rick 2.0 likes this.
  20. stephen cia
    Hello. New z homing routine. So much easier now
  21. stephen cia
    found a better removable bed system. using Geckotek RT plate. BOM has been updated over at github
    GrayUK likes this.
  22. stephen cia
    Testing more print bed non heated material
    GrayUK likes this.
  23. Neeter
    Neeter New
    Hi there
    I love this build, thank you so much for sharing. I'm attempting this build at home. However, I seem to be missing drawings for the "Y-Axis Motor Holder", which attaches to one end of the C-Beam / Y axis. Do you have that drawing avaialble? Thanks in advance and have a great day!
    Cheers,
    Avi
