Simple 3D-printed V-slot insert for screw-on accessories 2017-05-25
Insert for the V-slot that accepts a 4 mm plastic/wood screw
  1. FranciK
    FranciK New
  2. FranciK
    FranciK New
    I tweaked the dimensions so that it is snug (this is why ABS is recommended, it gives a bit). It was never a problem until now and I used 5 pieces so far. It could be a problem if you use a screw that is too big (>4 mm wood screw, I also used M3 screws for less critical parts), but you can still hold the insert in place using needle-nose pliers or a screwdriver.
  3. FranciK
    FranciK New
