C-Bot
  1. Russell Smyth
    This looks about exactly how I expect my bench to look in the somewhat near future, Maker Select and all!
    Did you use the Maker Select to print the parts for the C-Bot? What material did you use?
  2. Carl Feniak
    Carl Feniak Journeyman
    The base of the V is 9mm wide and 1mm tall, with two 1mm 45degree chamfers at each side. This makes the end of it 7mm. If you want to chose a part I can dimension it up, or you can measure them in 123D and ask when you need to.
    Spiffcow likes this.
  3. Spiffcow
    Spiffcow Well-Known
    Thanks!
    Hoping to get time to work on this soon.. I finally got my build "working" on Friday, but spent all weekend fighting Smoothieware to try to get a solid print because their auto bed leveling doesn't actually use the probe offset (as far as I can tell anyway).
  4. bill
    bill New
    I'm curious has anyone tried a cbeam for the Z? Single cbeam center rear was my thinking... Among other things it would reduce the printed parts and bearings needed.
  5. wackocrash5150
    wackocrash5150 Well-Known
    Just curious; where did the v2 files go? I found that it worked well.
  6. AK Eric
    AK Eric Journeyman
    lol, I deleted them, since I figured the new ones were moar better. I can get them back up there tonight.
  7. wackocrash5150
    @AK Eric[/USER] "moar better"? lmao
    On a side topic, I've had a casual reminder of the importance of polarity in wiring.... cable management and a nifty ramps enclosure resulted in a melted hotend fan and a fried SSR relay ....
    My own fault for being a dough head. I really should've packed it in about an hour earlier and just went to bed .... lol
    #2347 wackocrash5150, May 2, 2016
    Carl Feniak likes this.
  8. Carl Feniak
    Pesky electrical issues. Build is looking great though! Any issues with the rework parts?
  9. wackocrash5150
    Nothing big so far. General notes to date? Space was tight for the Z motor mounts on the offset bar when using corner brackets on both sides. I had to remove the bottom pair on the front to clear and make the screws line up.
    Another peeve is the cable/ptfe bundle going to the extruder. Seems to flop around and almost get caught on the left y-axis assembly, so i might think of something a little beefier and taller for the frame end of it.
    I have plans that even though I'm using 1.75mm filament, i'll run 3mm ID ptfe to the extruder so it can pull it through a little more freely, even if the bundle is bent.
    I also ordered an extra length of 2020 to tie to the front of the z-platform to keep the spacing equal. I either have a wonky bracket or slightly bent 2040 piece because the distance between them is slightly different. It'll also give me another screw mount location if I choose to go with another, or even just another place to mount a corny logo plate of some sort for my own entertainment.
    I think I lucked out that the rework STLs were available by the time I started printing for my build. So far so good. It's a LOT more straight forward than when I was building and tuning my Kossel. I have a smoothie on it, which I like almost all things of (yes, no soft-limit options are a pain, especially on a delta) but I keep hearing that it might be overkill on a CoreXY. I'm following post on those using the E3D Titan as it would be great to loose some weight on the gantry using a pancake nema.
    So back to the original question; the reworks are great so far. And just a little hat tip to you Carl and the other regular contributors for a great build and great development!
    I love this frickin printer!
  10. bill
    bill New
    which thread? I'm very early in the planning stages for building this bot and was planning to go with the titan extruder direct
  11. wackocrash5150
    Elmo is using one. Pics a few pages back. Looks like he had a mishap but he might just needed a "moar better" fan.... ;)
    Hope it's fixed soon if it isn't already sir.
  12. Elmo Clarity
    Elmo Clarity Journeyman
    I had the same peeve as you. Here is how I resolved it...
    Cable chains. The only part I couldn't run through it was the PTFE tube to feed the filament. But with that being the only part hanging out, it is not much of an issue.
  13. bill
    bill New
    Do you have the titan carriage sources posted anywhere? stl or scad work for me.
  14. Elmo Clarity
    Here is the link back to the picture of my Titan and carriage...
    C-Bot | Page 77 | OpenBuilds
    I am including the STL files for them. I am also adding the files for AK Eric's fan shroud and the V2 shroud. He has a V3 out now, but haven't been able to test it. Because the hotend is offset from the center, I had to move the shroud over to match it.
    RacerBo, wackocrash5150 and bill like this.
  15. Elmo Clarity
    Just posted them. That was suppose to be a reply to your post but guess I clicked the wrong message.
  16. bill
    bill New
    Very much appreciated thanks!
    Have you printed any flexible stuff with this yet? Looks like it should work fine.
  17. Carl Feniak
    FYI, I have created a thingiverse collection of C-bot accessories and remixes as once you get remixes of remixes it is a bit hard to track stuff down. It will also include generally useful things for the project. Let me know if I am missing this that would help others. Previously I was listing them all on the main page but this will be easier to maintain.
    C-Bot: A Collection by cfeniak
    AK Eric and bill like this.
  18. Elmo Clarity
    Haven't yet. I was planning on trying it Saturday until I had that blow out. Going to try some soon.
    Also have been thinking about doing a dual Titan carriage. Each of those pancake motors are less than half the weight of the larger one so doing two shouldn't be too big of an issue. I just don't have a second extruder to test it with... yet. :)
  19. Elmo Clarity
    I'll get the Titan carriage posted later tonight so that can be added to the collection.
  20. Elmo Clarity
    FYI. I realized there were a couple other files I needed to add. I am working on a Thingiverse project where I will have all the files. Will post the link when I get it finished.
  21. Spiffcow
    Spiffcow Well-Known
    From the pics it looks like you could mount almost any extruder in place of the Titan.. Is that the case?
  22. Elmo Clarity
    Depends on the extruder. The Titan basically uses a standard Nema 17 mount so if the extruder attached the same way, it could work.
  23. Elmo Clarity
  24. Spiffcow
    Spiffcow Well-Known
    Looks like I know what I'll be printing tonight.
    Did you do this in OpenSCAD? If so, do you mind sharing that as well? I'm guessing the changes for most other extruder mounts should be pretty minor
  25. Elmo Clarity
    No laughing at my OpenSCAD code. :)
  26. Elmo Clarity
    Just tried printing some NinjaFlex. While I was able to get it to come out of the nozzle, I don't have the settings tuned in for it to print right. I have never had much luck with it so the problem is probably me.
    Anyone have any suggestions for printing NinjaFlex?
  27. AK Eric
    AK Eric Journeyman
    I use it on my rep1 pretty often to make friends iphone cases ;) Only big adjustments I make from normal printing are: (4mm nozzle)
    * 30mm\sec travel speed (slow, very slow)
    * 250ish extrusion temp
  28. Elmo Clarity
    What bed temp do you use?
  29. bill
    bill New
    When I print ninjaflex or semiflex I use the following:
    hotend: e3d v6, .4mm 1.75
    hotend temp: 228
    bed temp: n/a
    bed treatment: blue painters tape or 3d eez. Note, iirc printing to buidltak will destroy the section of buildtak ;)
    print speed is the most critical. When talking with Flint in makerstoolworks irc channel, he advised 20-30mm / sec. no retraction and have all print speeds the same - no change in speed for infill etc.
    I found ninjaflex to print fairly consistently and runs smooth. It does ooze a good bit iirc - its been a little while since I needed to print anything with it.
    I'm curious with the titan what kind of speeds you could achieve with the ninjaflex. I had issues with backpressure and pulling the filament out of the hotend / binding. Part of why I'm interested in the titan actually.
  30. vacalos
    vacalos New
    I am new to this thread and would like to attempt to build this 3d printer because it is so well thought out, but I would like to have dual extruders. Can anyone advise me on this? The extruder carriage appears to be made to accept 2 extruders, but I have not seen any examples of this? Any advice would be appreciated.
