Problem With Post Processing in Fusion 360
Discussion in 'General Talk' started by jsaction, Mar 26, 2024.
  1. jsaction
    jsaction New
    Hello new poster here,
    I built a plasma table a few years ago and have been routinely using the open builds post processor in fusion 360 for it. I have been using V1.0.30 without issue until recently, I then decided to upgrade to V1.0.40 and am still getting the same issue. I am unable to post at all and this is the feedback I am getting from Fusion 360.
    I have never seen this error before. Any feedback on this issue would be greatly appreciated.
  2. David the swarfer
    hmmm, looks like they have created a new internal property named 'power' and made it readonly.
    I will post a new version tonight
  3. jsaction
    jsaction New
    Thanks for the update. I just updated to the latest version of Fusion 360 and started getting this problem. I will give it a try as soon as I can.
  4. David the swarfer
  5. jsaction
    jsaction New
    Looks like that fixed the issue. Thanks for the quick update.
  6. BrandonLebrun
    where did you post the update? i'm having the same issue
  7. Alex Chambers
    David has posted the link in the message above.
    #7 Alex Chambers, Mar 27, 2024
  8. BrandonLebrun
    Thanks! I downloaded it. Now how do I update my fusion with the new version?
  9. BrandonLebrun
    I downloaded the update (V1.0.41). I am NEW NEW NEW to this and haven't a clue how to do this. Please dumb this down for me. I've had responses which I appreciate but the answers seem to require a stronger understanding of computers and I just don't have it. Computer programming is not my strong suit. I can draw in fusion/ sketchup just fine. Just when I got this thing going there's an update that requires reprogramming or updating and I'm stalled again. I have spent countless hours trying to get this table operating. I've made less than half a dozen cuts. PLEASE HELP!!!!
  11. Grant Oglesby
    Thank you Sir.
  12. Rsat
    Rsat New
    Exactly my situation as well. Thank you both.
  13. BrandonLebrun
    Thanks! I suppose I need to work on my computer skills. I managed to get it to work. Took me a while, but it worked. I appreciate your help! Thanks again.
  14. vishesh
    vishesh New
    I am getting an error "Hard limit triggered" after using the latest post processor of open builds for fusion 360. Job start -- runs for some time and then I get this error. Error is at random time. My old g-codes are working properly. Today my earlier PP stopper working and it was showing some error, so I downloaded the new one and since then I am getting this issue.
  16. vishesh
    vishesh New
    But all my old g-codes are working properly which I have made using the openbuilds PP
    Well, the Hard limit error specifically means, a limit switch was hit. Thus the question
    It either does (incorrect options in post but unlikely to be "random" ; Or something mechanic making machine lose position) or its a false trigger caused by EMI.
    The post cannot "cause" a false alarm
  18. vishesh
    vishesh New
    Thanks a lot for your help. Can you please let me know what incorrect options selected in post may cause this error. I will check it, if by mistake there is some incorrect selection in post.
  19. Peter Van Der Walt
    So, by that you are confirming you are actually running into a switch? Not a random error, but an actual Limit hit?
  20. profey88
    profey88 New
    im having the same issue as the original poster. but when i click on the github link to get v1.0.41 it only shows the latest update is v1.0.37
  21. Misterg
    Misterg Veteran
