Hi All, X-32 (Configured as a lightly customised Workbee 1510) CONTROL v1.0.638 firmware grblHAL 1.1f I am having the same issues identified in this thread: https://openbuilds.com/threads/openbuilds-xyz-probe-not-working Everything else working fine. I have read section 7.1 / 7.2 The solution seems to be to update the firmware, all good. I run the Firmware Flashing Tool with settings: * X32 * FTDI USB to Serial COM5 * 2/3 Axes CNC/Laser: Dual Y I get: [ disconnect ] PORT INFO: Port closed [ Firmware Upgrade ] connected [ Firmware Upgrade ] reset complete. [ Firmware Upgrade ] flashing, please wait... [ Firmware Upgrade ] FLASH FAILED! How do I overcome the FLASH FAILED! issue? Any advice gratefully received. The software is running on an up to date W11 laptop (Ryzen 9 5900HX) grbl settings on connect are: [13:02:00] [ connect ] PORT INFO: Port is now open: COM5 - Attempting to detect Firmware [13:02:00] [ connect ] Checking for firmware on COM5 [13:02:00] [ connect ] Detecting Firmware: Method 1 (Autoreset) [13:02:00] [ ] ok [13:02:01] [ connect ] Detecting Firmware: Method 2 (Ctrl+X) [13:02:01] [ ] GrblHAL 1.1f ['$' or '$HELP' for help] [13:02:03] [ $$ ] $0=10.0 ;Step pulse time, microseconds [13:02:03] [ $$ ] $1=255 ;Step idle delay, milliseconds [13:02:03] [ $$ ] $2=0 ;Step pulse invert, mask [13:02:03] [ $$ ] $3=0 ;Step direction invert, mask [13:02:03] [ $$ ] $4=0 ;Invert step enable pin, boolean [13:02:03] [ $$ ] $5=7 ;Invert limit pins, boolean/mask [13:02:03] [ $$ ] $6=1 ;Invert probe pin, boolean [13:02:03] [ $$ ] $7=0 ;Disable spindle with 0 speed, boolean [13:02:03] [ $$ ] $8=0 ;Ganged axes direction invert as bitfield [13:02:03] [ $$ ] $10=511 ;Status report options, mask [13:02:03] [ $$ ] $11=0.020 ;Junction deviation, millimeters [13:02:03] [ $$ ] $12=0.002 ;Arc tolerance, millimeters [13:02:03] [ $$ ] $13=0 ;Report in inches, boolean [13:02:03] [ $$ ] $14=0 ;Limit pins invert, mask [13:02:03] [ $$ ] $15=0 ;Coolant pins invert, mask [13:02:03] [ $$ ] $16=0 ;Spindle pins invert, mask [13:02:03] [ $$ ] $17=0 ;Control pins pullup disable, mask [13:02:03] [ $$ ] $18=0 ;Limit pins pullup disable, mask [13:02:03] [ $$ ] $19=0 ;Probe pin pullup disable, boolean [13:02:03] [ $$ ] $20=0 ;Soft limits enable, boolean [13:02:03] [ $$ ] $21=1 ;Hard limits enable, boolean [13:02:03] [ $$ ] $22=1 ;Homing cycle enable, boolean (Grbl) / mask (GrblHAL) [13:02:03] [ $$ ] $23=3 ;Homing direction invert, mask [13:02:03] [ $$ ] $24=150.0 ;Homing locate feed rate, mm/min [13:02:03] [ $$ ] $25=2500.0 ;Homing search seek rate, mm/min [13:02:03] [ $$ ] $26=25 ;Homing switch debounce delay, milliseconds [13:02:03] [ $$ ] $27=5.000 ;Homing switch pull-off distance, millimeters [13:02:03] [ $$ ] $28=0.000 ;G73 retract distance, in mm [13:02:03] [ $$ ] $29=0.0 ;Step pulse delay (ms) [13:02:03] [ $$ ] $30=24000.000 ;Maximum spindle speed, RPM [13:02:03] [ $$ ] $31=0.000 ;Minimum spindle speed, RPM [13:02:03] [ $$ ] $32=0 ;Laser-mode enable, boolean [13:02:03] [ $$ ] $33=5000.0 ;Spindle PWM frequency [13:02:03] [ $$ ] $34=0.0 ;Spindle off Value [13:02:03] [ $$ ] $35=0.0 ;Spindle min value [13:02:03] [ $$ ] $36=100.0 ;Spindle max value [13:02:03] [ $$ ] $37=0 ;Stepper deenergize mask [13:02:03] [ $$ ] $39=1 ;Enable printable realtime command characters, boolean [13:02:03] [ $$ ] $40=0 ;Apply soft limits for jog commands, boolean [13:02:03] [ $$ ] $43=1 ;Homing passes [13:02:03] [ $$ ] $44=4 ;Homing cycle 1 [13:02:03] [ $$ ] $45=3 ;Homing cycle 2 [13:02:03] [ $$ ] $46=0 ;Homing cycle 3 [13:02:03] [ $$ ] $62=0 ;Sleep Enable [13:02:03] [ $$ ] $63=2 ;Feed Hold Actions [13:02:03] [ $$ ] $64=0 ;Force Init Alarm [13:02:03] [ $$ ] $65=0 ;Require homing sequence to be executed at startup [13:02:03] [ $$ ] $70=7 ;Network Services [13:02:03] [ $$ ] $73=1 ;Wifi Mode [13:02:03] [ $$ ] $74=NaN ;Wifi network SSID [13:02:03] [ $$ ] $75=NaN ;Wifi network PSK [13:02:03] [ $$ ] $100=26.667 ;X-axis steps per millimeter [13:02:03] [ $$ ] $101=26.667 ;Y-axis steps per millimeter [13:02:03] [ $$ ] $102=200.000 ;Z-axis steps per millimeter [13:02:03] [ $$ ] $110=8000.000 ;X-axis maximum rate, mm/min [13:02:03] [ $$ ] $111=8000.000 ;Y-axis maximum rate, mm/min [13:02:03] [ $$ ] $112=250.000 ;Z-axis maximum rate, mm/min [13:02:03] [ $$ ] $120=150.000 ;X-axis acceleration, mm/sec^2 [13:02:03] [ $$ ] $121=150.000 ;Y-axis acceleration, mm/sec^2 [13:02:03] [ $$ ] $122=150.000 ;Z-axis acceleration, mm/sec^2 [13:02:03] [ $$ ] $130=1550.000 ;X-axis maximum travel, millimeters [13:02:03] [ $$ ] $131=3050.000 ;Y-axis maximum travel, millimeters [13:02:03] [ $$ ] $132=80.000 ;Z-axis maximum travel, millimeters [13:02:03] [ $$ ] $300=NaN ;Hostname [13:02:03] [ $$ ] $302=192.168.5.1 ;IP Address [13:02:03] [ $$ ] $303=192.168.5.1 ;Gateway [13:02:03] [ $$ ] $304=255.255.255.0 ;Netmask [13:02:03] [ $$ ] $305=23 ;Telnet Port [13:02:03] [ $$ ] $306=80 ;HTTP Port [13:02:03] [ $$ ] $307=81 ;Websocket Port [13:02:03] [ $$ ] $341=0 ;Tool Change Mode [13:02:03] [ $$ ] $342=30.0 ;Tool Change probing distance [13:02:03] [ $$ ] $343=25.0 ;Tool Change Locate Feed rate [13:02:03] [ $$ ] $344=200.0 ;Tool Change Search Seek rate [13:02:03] [ $$ ] $345=100.0 ;Tool Change Probe Pull Off rate [13:02:03] [ $$ ] $370=0 ;Invert I/O Port Inputs (mask) [13:02:03] [ $$ ] $384=0 ;Disable G92 Persistence [13:02:03] [ $$ ] ok [13:02:03] [ $I ] [VER:1.1f.20220325:workbee1510] [13:02:03] [ $I ] [OPT:VNSL2,35,1024,3,0] [13:02:03] [ $I ] [NEWOPT:ENUMS,RT+,HOME,TC,SED,WIFI,SD] [13:02:03] [ $I ] [FIRMWARE:grblHAL] [13:02:03] [ $I ] [NVS STORAGE:*FLASH] [13:02:03] [ $I ] [DRIVER:ESP32] [13:02:03] [ $I ] [DRIVER VERSION:220327] [13:02:03] [ $I ] [DRIVER OPTIONS:v4.3.2-555-gb4ef1b80a2-dirty] [13:02:03] [ $I ] [BOARD:BlackBox X32] [13:02:03] [ $I ] [AUX IO:1,0,0,0] [13:02:03] [ $I ] [WIFI MAC:94:B5:55:31:02:C0] [13:02:03] [ $I ] [IP:0.0.0.0] [13:02:03] [ $I ] [PLUGIN:SDCARD v1.05] [13:02:03] [ $I ] [PLUGIN:ESP32 WebUI v0.03] [13:02:03] [ $I ] ok [13:02:03] [ $G ] [GC:G0 G54 G17 G21 G90 G94 G49 G98 G50 M5 M9 T0 F0 S0.] [13:02:03] [ $G ] ok [13:02:04] [ connect ] Firmware Detected: grbl version 1.1f on COM5
Make sure to click the X32 tab. Even if it's already selected. That seems to be trying to flash a 4X. Might have a bug with the default selection, so lets test if clicking the tab to assert the controller type helps.
Thanks Peter. Partial success. I positively selected each option: X32 FTDI USB to Serial COM5 2/3 Axes CNC/Laser: Dual Y The Update Log is: [15:19:18] [ Firmware Upgrade ] [Starting...] [15:19:20] [ disconnect ] PORT INFO: Port closed [15:19:20] [ Firmware Upgrade ] esptool.py v2.6 Serial port COM5 Connecting... [15:19:20] [ Firmware Upgrade ] . [15:19:21] [ Firmware Upgrade ] . [15:19:22] [ Firmware Upgrade ] Chip is ESP32D0WDQ6 (revision 1) Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None MAC: 94:b5:55:31:02:c0 Uploading stub... Running stub... Stub running... Changing baud rate to 460800 Changed. Configuring flash size... Auto-detected Flash size: 4MB Compressed 17104 bytes to 11850... Writing at 0x00001000... (100 %) [15:19:22] [ Firmware Upgrade ] Wrote 17104 bytes (11850 compressed) at 0x00001000 in 0.3 seconds (effective 476.8 kbit/s)... Hash of data verified. Compressed 3072 bytes to 131... Writing at 0x00008000... (100 %) [15:19:22] [ Firmware Upgrade ] Wrote 3072 bytes (131 compressed) at 0x00008000 in 0.0 seconds (effective 1536.0 kbit/s)... Hash of data verified. Compressed 877856 bytes to 593513... Writing at 0x00010000... (2 %) [15:19:23] [ Firmware Upgrade ] Writing at 0x00014000... (5 %) [15:19:23] [ Firmware Upgrade ] Writing at 0x00018000... (8 %) [15:19:24] [ Firmware Upgrade ] Writing at 0x0001c000... (10 %) [15:19:24] [ Firmware Upgrade ] Writing at 0x00020000... (13 %) [15:19:24] [ Firmware Upgrade ] Writing at 0x00024000... (16 %) [15:19:25] [ Firmware Upgrade ] Writing at 0x00028000... (18 %) [15:19:25] [ Firmware Upgrade ] A fatal error occurred: Failed to write compressed data to flash after seq 6 (result was C100) [15:19:25] [ Firmware Upgrade ] [exit:2] [15:19:25] [ Firmware Upgrade ] Firmware Update FAILED! Please review the logs above, or try again
Morning Peter. This seems to be an issue that just keeps giving. This morning, when I went to try the firmware update again, I cannot connect to the X32. I have read 6.3 and wiring is unchanged, COM port is good, drivers are good (2.12.36.4 07/05/21). The only change made is to remove a USB extension cable in order to minimise the potential for another comms interruption. Log screen dump follows. Thanks, Fred. [11:31:35] [ ] entry 0x400805e4 [11:31:35] [ ] ets Jun 8 2016 00:22:57 [11:31:35] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:35] [ ] configsip: 0, SPIWP:0xee [11:31:35] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:35] [ ] modeIO, clock div:2 [11:31:35] [ ] load:0x3fff0030,len:1184 [11:31:35] [ ] load:0x40078000,len:12784 [11:31:35] [ ] load:0x40080400,len:3040 [11:31:35] [ ] entry 0x400805e4 [11:31:35] [ ] ets Jun 8 2016 00:22:57 [11:31:35] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:35] [ ] configsip: 0, SPIWP:0xee [11:31:35] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:35] [ ] modeIO, clock div:2 [11:31:35] [ ] load:0x3fff0030,len:1184 [11:31:35] [ ] load:0x40078000,len:12784 [11:31:35] [ ] load:0x40080400,len:3040 [11:31:35] [ ] entry 0x400805e4 [11:31:35] [ ] ets Jun 8 2016 00:22:57 [11:31:35] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:35] [ ] configsip: 0, SPIWP:0xee [11:31:35] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:35] [ ] modeIO, clock div:2 [11:31:35] [ ] load:0x3fff0030,len:1184 [11:31:35] [ ] load:0x40078000,len:12784 [11:31:35] [ ] load:0x40080400,len:3040 [11:31:35] [ ] entry 0x400805e4 [11:31:35] [ connect ] Detecting Firmware: Method 3 (others that are not supported) [11:31:35] [ ] ets Jun 8 2016 00:22:57 [11:31:35] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:35] [ ] configsip: 0, SPIWP:0xee [11:31:35] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:35] [ ] modeIO, clock div:2 [11:31:35] [ ] load:0x3fff0030,len:1184 [11:31:35] [ ] load:0x40078000,len:12784 [11:31:35] [ ] load:0x40080400,len:3040 [11:31:35] [ ] entry 0x400805e4 [11:31:35] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:36] [ ] ets Jun 8 2016 00:22:57 [11:31:36] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:36] [ ] configsip: 0, SPIWP:0xee [11:31:36] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:36] [ ] modeIO, clock div:2 [11:31:36] [ ] load:0x3fff0030,len:1184 [11:31:36] [ ] load:0x40078000,len:12784 [11:31:36] [ ] load:0x40080400,len:3040 [11:31:36] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:37] [ ] ets Jun 8 2016 00:22:57 [11:31:37] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:37] [ ] configsip: 0, SPIWP:0xee [11:31:37] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:37] [ ] modeIO, clock div:2 [11:31:37] [ ] load:0x3fff0030,len:1184 [11:31:37] [ ] load:0x40078000,len:12784 [11:31:37] [ ] load:0x40080400,len:3040 [11:31:37] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ ] ets Jun 8 2016 00:22:57 [11:31:38] [ ] rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) [11:31:38] [ ] configsip: 0, SPIWP:0xee [11:31:38] [ ] clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 [11:31:38] [ ] modeIO, clock div:2 [11:31:38] [ ] load:0x3fff0030,len:1184 [11:31:38] [ ] load:0x40078000,len:12784 [11:31:38] [ ] load:0x40080400,len:3040 [11:31:38] [ ] entry 0x400805e4 [11:31:38] [ connect ] ERROR!: No supported firmware detected - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for more details. Closing port COM5 [11:31:39] [ disconnect ] PORT INFO: Port closed
That's the half-written firmware from the day before, unable to boot of course (it didn't finish writing remember). Usb Extensions are a bad idea, and should be the cause of the comms drop during flashing the day before. Complete a successful firmware flash first.
