Openbuilds Blackbox PWM connections
Discussion in 'Controller Boards' started by GS76, Aug 29, 2022.
Tags:
  1. GS76
    GS76 Well-Known
    Hi all,
    I have just purchased the Openbuilds Blackbox.
    In preparation for its arrival, I need to prepare the connections required for the 0-5V PWM speed control.
    If I am not mistaken the connection is the "tool head" connector. See the link below.
    docs:blackbox:tour-left.png [OpenBuilds Documentation]
    What type of connectors/wiring should I purchase for this connection?
    I would appreciate any guidance in this regard.
    Connectors are included with the BlackBox
    Wiring: If your spindle controller only needs a GND+PWM you can use the 2-conductor: Xtension Wire By the Foot
  3. GS76
    GS76 Well-Known
    Thank you for the reply Peter.
    Much appreciated.
