Grbl Error 22 Feed rate has not been set or defined
Discussion in 'General Talk' started by Cool Monkey, Feb 26, 2022.
  1. Cool Monkey
    Using Carveco and Openbuilds (inch) as the post processor. It made it through around half way when the router kicked off and took a dove into my project and I received that error. I have attached the file if anyone could help me to narrow it down to the file or hardware I would deeply appreciate it.
    Perhaps EMI corruption? See docs:blackbox:faq-emi [OpenBuilds Documentation]
  3. David the swarfer
    I vote EMI corrutping the USB communications.
    move USB cable away from all power cables, from the PSU and from the drivers to the steppers
    use SHORT USB cable, like 2 feet long, of good quality.
  4. David the swarfer
    also could be USB port power saving caused a controller reset. docs.openbuilds.com for how to turn off power saving
  5. David the swarfer
    I ran your file through a controller in test mode without any errors, so not the Gcode , pointing to an EMI problem on your machine
  6. Cool Monkey
  7. Cool Monkey
    Thanks for everyone help and time. Ill check the USB!
