Vslot Kossel
Discussion in '3D printers' started by mytechno3d, Apr 3, 2014.
  1. mytechno3d
    mytechno3d Veteran
    mytechno3d published a new build:
  2. Mark Carew
    Nice job on this build and I have to say the FSR Sensors are a great idea for the bed leveling :thumbsup: The only thing I would warn against are the steel v wheels on the aluminum rails, could wear it down in time. I would suggest using the delrin solid v wheels in their place
    Robert Hummel likes this.
  3. mytechno3d
    mytechno3d Veteran
    Yes , i will upgrade "my vslot kossel" with delrin wheel asap ...
  4. Mark Carew
    Sounds good @mytechno3d I think you will be much happier in the long run.
  5. CommanderK
    Hi did you ever do stl or other files for this build looks great machine
  6. Gaou²
    Gaou² New
    are there any plans an BOM anything ?
