Openbuilds Xtension Connector Lid for Nema 23 Cover 2019-02-12
Xtension connector lid for motor cover.
  1. sharmstr
  2. Adam Filipowicz
    Adam Filipowicz Journeyman
    Nice Job!
  3. Netechsys
    Netechsys Journeyman
    Hello.. Ok.. I am having a problem with the attached file.. I have downloaded the body from Thingverse, and will be printing it shortly. But, I can not get the lid above to scale to the right size for this. When I open the STL, it is only like 1.x mm wide. And I can not get it to scale to the right size.. I have tried in Vectric and Freecad.... No luck on either.. Any help would be greatly appreciated!
    Ok.. I am going to give up on this.. I tried F360, and now the body is huge! I give up on scaling.... Just not clicking tonight..
    #3 Netechsys, Feb 10, 2021
  4. Christian James
    Christian James Journeyman
    Use Netfabb to scale it. Where is the attached file by the way?
  5. Netechsys
    Up at the top.
  6. Christian James
    Haha, its the old mm/inch problem. scale it up by 25.4 and its good.
  7. JustinTime
    I found that importing .stl files into Fusion360 they are 10 times the original size. I use the Scale feature to select the imported model and then enter 0.1 for the new scale and it, so far, always came out the perfect size.
  8. sharmstr
