Currently in the design stage, I am attempting to design a 4(+)-axis machine to specifically build custom pool cues. However, I am providing a bit of a base space for limited size flat plates as well.
This build is based on the layout of the WorkBee design. It uses two 1500mm Y-Axis Actuators, a 750mm X-Axis Actuator, and a 250mm Z-Axis Actuator, with a central beam with a 4th axis Lathe Head- and Tail-Stock setup. This will allow me to initially be able to turn the piece incrementally to cut patterns into the cues at designated locations around the surface. Eventually, I want to be able to make the Y-Axis fixed and translate it into 4th axis rotation, to cut scroll patterns around the cues.
WorkBee CNC Lathe and Flat Router
Build in 'Other Lathe Build' published by Jason @ MCC, Aug 30, 2020.
A 750x1500mm WorkBee with a 4th Axis Rotary attachment/Lathe Bed.
JDavis3rd likes this. -
Build Author Jason @ MCC, Find all builds by Jason @ MCC
Cut inlay pockets and inserts into pool cues and other flat/turned projects. -
