Floating head assembly.
WLOG (WIP)
- I had to use only parts I already have.
- Z axis and floating head should be extendable - I want to have possibility to replace plasma torch with drag knife or other tools when needed.
Some tests with markers.
1. Floating Head Plate
- V-Slot Gantry Plate 20-80mm
- 4x Aluminum Spacer 6mm
- 4x M5 12mm screws
2. Z limit switch plate
- M5 10mm screw
- Nylon Insert Lock Nut M5
- L Bracket Single
3. Floating head wheels assembly
- 4x 30mm Low Profile Screws
- 4x M5 Slot
- 4x Nylon Insert Lock Nut M5
- 4x Precision shim
- 2x Eccentric 0.25in spacer
- 2x Aluminium 0.25in spacer
- 4x V Wheels
4. Floating part
I created custom plate from 2mmx20mm aluminium flat. It will be used as metal part for proximity sensor/switch.
- 2x T-nut
- 2x Precision Shim
- 2x M5 8mm Standard screw
- 1x M5 8mm Low profle screw
- Custom Top Plate
- 200mm 20x40 V Slot Profile
Plate sketch:
Assembly:
Two screws will act as limit for profile from falling down. It will stop at V-Slot Gantry Plate.
Assembled:
5. Assembly of floating part with floating head plate
6. Floating head proximity sensor/switch
- Custom alumiunium plate
- Custom 3D printed model
- Proximity sensor M12 NPN NO
- 2x M5 8mm low profile screws
- 2x M5 12mm low profile screws
- 2x Nylon Insert Lock Nut M5
Plate sketch:
Proximity holder:
7. Connecting to linear actuator 250mm
8. Z Axis limit
Assembled:
W|W plasma/drag knife 1500x1500 (floating head & z-axis)
Build in 'Plasma Cutter Builds' published by wojak, Feb 6, 2019.
Step by step designing and implementing of my plasma approach
Build Author wojak, Find all builds by wojak
