      PeeNaPle is a modular controller BoB for Teensy 4.1. It is designed with Pick and place machines using Open PnP software in mind, but is also 3D Printing, CNC and other Cartesian machines oriented, thanks to an extension and adapter daughter boards eco-system being developed. It is built upon a 6 layer PCB, offering stability an immunity to EMF and electric noises. it Natively offers 8 stepper outputs, 4 End_Stops, UEXT port, Extension port, USB_HOST, Ethernet PHY and CAN_FD. Among the adaptors and extensions being developed you can find a stepper driver adapter to use your favorite TMC2208/09 or else as well as a powerful driver with closed loop so you never miss a step, capable of handling not less than 10A, just to name those 2! Tolerance of up to 35V Max Power In and offers 12V, 5V 3A DCDC, and 3.3V 1A for your convenience. Which are available on the extension ports so you do not need complicated wiring!
      You can follow my projects @CrazzyFrenchDude on Instagram
      Website and store coming soon @ www.crazzyfrenchdude.com
    • CERN (CERN-OHL1.2+) Open Hardware Licence
