      This is a build in progress. I'm hoping to have it up and running within a few weeks. So far I have the main structure built and the parts for the enclosure.
      Electronics & Other
      Duet 2 WiFi w/ external Antenna
      PanelDue 7i
      E3D Copper Heater Block
      E3D Nozzle X .04
      PT100 Sensor
      E3D Smart Effector
      Mean Well HRP-600-24 PSU
      The Nimble extruder
      Berd-Air system(not sure about this, need advice)
      Here's the main structure.
      The main structure consists of 2040 extrusions. It's 5ft(1524mm) tall. There is some wobble at the top but with the enclosure I'm going to have it connect to that to strengthen it up. All the printed parts are PETG. I'm working on a BOM, I'll have it up soon. I'll update this as I go along.
      Moved the rest of the pictures to attached files. Figured it would be better for anyone on mobile devices.
      Update: 8/31/2019
      Updated main picture, to newest 3d model. I've also updated some stl's, the inside top and bottom bracket enclosures won't connected to upright, I forgot to move the hole when I made them thicker, from 2mm to 5mm. I'll update them later. They still work as the outer brackets hold everything very well.
      MaryD and Rick 2.0 like this.
    I wanted a build area of 24-25 inches that could print at fast speeds and that wouldn't break the bank.
    3 2040 Extrusion 1524MM Link Uprights
    3 2040 Extrusion 280mm Link upper inner frame
    3 2040 extrusion 203mm Link upper inner frame
    6 2040 extrusion 635mm Link outer frame
    1 25" cast aluminum plate .25" thick Link
    9 1" 6061round bar Link bed sits on these
    3 Nema 23, 1.9nm, 3a stepper motors Link
    6 Magballarms 600mm Link magballarms.com
    1 110v 1400w 610mm silicone heater Link Shenzhen Ali Brother Tech from aliexpress.com
    12 Xtreme Solid V Wheels Link
