Build List
Build Author OpenBuilds Views 16333
BlackBox X32
The next level of CNC motion control solutions. Packed with advanced new features and built on the reliability of the proven BlackBox system
Build Author Elias Ramburger Views 121
600 volume 3D-Printer
Build Author Retsaj Views 49603
Build Author Michael.M Views 34601
7050 Sphinx
My Lead 1010
C-beam Machine - Modesty
Build Author Joe Young Views 10602
Rack and Pinion (Death to Belts)
Low profile rack and pinion linear actuator design
Sphinx 66
Build Author Quentin Karmark Views 5169
Laguna Swift 4X4 CNC mill retrofitted with OpenBuilds
Used Laguna Swift 4X4 CNC mill with Water-cooled Spindle and RichAuto serial pendant retrofitted with OpenBuilds/Blackbox/Interface
Techsoft Roland TS-30 rebuild
Openbuilds 4x8 cnc
Build Author Mark Carew Views 18230
Build Author OpenBuilds Views 21934
INTERFACE CNC Touch Control System
Super cool standalone Human-Machine Interface for controlling your CNC machines!
Build Author StrictlyScale Views 6176
Lead1010 Build with Enclosure
First time CNC builder puts together a Lead1010 machine.
Build Author EvanH Views 601
Build Author Keith Davis Views 19081
Vulcan MAX
5'x10' CNC Plasma/Mill Table
Plasma Mill CNC
LEAD Lathe
Build Author Bob Darrow Views 5875
BA3DP
modifying ACRO
"Hirata scrap find" CNC
First CNC and first attempt at building one also, so yeah... good luck to me!
Z Floating Head
KRE CO2 2x4 Laser
Large Format CO2 Laser Cutter
Build Author Mark Carew Views 72591
Build Author Mark Carew Views 56880
Build Author Kyo Views 21450
Sphinx 55
Build Author cdsmith12 Views 23777
Build Author openhardwarecoza Views 70801
openBuilds FreeBURN-1 V-slot CO2 Laser (60-100w)
DIY Lasercutter: Budget orientated, medium sized (60-100w), safety first, based on Lasersaur software toolchain
Build Author Spark Concepts Views 12956
CNC xPRO V4
Take your build to the next level with the CNC xPRO V4!
cnc back stop for brake press
back stop build
Build Author Troy Proffitt Views 23230
Hydraulic lifting table
Build Author Mark Carew Views 116348
C-Beam™ Linear Actuator
My large machine 48 X 48
Build Author Frank Del Favero Views 5006
Build Author Mark Carew Views 176286
LEAD CNC 1010 (40" x 40")
Build Author sausagePaws Views 71991
Build Author Ryan Lock Views 121526
WorkBee CNC Machine
Build Author CONUCON Views 2419
3DTwinX Gantry CNC System
Belt driven 3-axis linear system for high precision and low costs. > Threading and linear real cutting needed
Build Author Mark Carew Views 27332
High Z Mod for Lead CNC
LR/BS CNC Router
An easy to source/easy to build, yet quite robust CNC router. This design has not yet be implemented.
Build Author tshilling Views 30991
Build Author Mac6986 Views 14666
Build Author Ryan Lock Views 128570
Ooznest OX CNC Machine
Heavy Metal
Build Author Gerald Klein Views 12924
Reworked Sepcraft 420 CK
Its alive !
Build Author Kyo Views 29083
Sphinx 1050
Salmon Sphinx 1.0
Build Author Suhmanda Views 1840
DIY CNC SPINDLE
CNC SPINDLE FOR DIY ROUTERS AND MILLING MACHINES ITSRS-985 MOTOR HAS MUCH BEFINITS THAN ANY OTHER DC MOTOR IN MARKET
Build Author Scott Drake Views 12947
1500x1000 CNC Router
Gauthali V2.0 DIY 3D printer
Build Author alan richard Views 44800
Core-XY Cube
Build Author Rob Taylor Views 15234
M4: 1510SS Heavy Mk.I
Build Author Keith Davis Views 31957
OneZ i3
Build Author jaron kennell Views 3529
Rezo 1390 100W CO2 Laser
TrueUp Bold
Pneumatic cnc cutter with festo drive
CNC Glass cutter
CNC Cutter Knife
CNC knife cutter with loline blades
CNC Linear Slide for DIY project
Low cost cnc linear drive for making any xyz cnc structure
Plasma Table 006
Build Author Mark Carew Views 251397
C-Beam® Machine - Plate Maker
Build Author Mark Carew Views 13003
C-Beam XLarge X/Y Table
Build Author Ryan155 Views 8098
RIGCNC
I made a mill from first principles because I didn't like any of the ones that were out there, More info can be found on the website RigCNC.com
Build Author OpenBuilds Views 11927
C-Beam® Tension XL Linear Actuator
Build Author that-jim Views 6621
Z-Axis Upgrade For My Sphinx
Build Author that-jim Views 40623
Build Author MattR Views 16227
Build Author Damian V-SLOT Poland Views 1634
LEGO BOX
Build Author OpenBuilds Views 17673
OpenBuilds Table Series
The OpenBuilds Table Series offers a modular table structure that grows with your needs.
My ACRO Build
An ACRO laser put together with some repurposed and some new parts.
Build Author Mark Carew Views 67695
OpenBuilds Workbee 1010 (40" x 40")
The OpenBuilds WorkBee 1010 - 1000x1000 Lead Screw Driven CNC Machine
A Rolling Plotter
Project Completed.
Build Author UltiBots Views 33869
UltiBots CB3030 CNC Router
Build Author Yanou Fishel Views 7807
Beefed up Minimill
C-Beam Machine XLarge
A rigid and wide format, plate and carving CNC.
Build Author Sigifredo Cruz Rojas Views 2390
ALl included interface
Build Author 2SIsurf Views 4106
Hotwire cnc Surfboards
Xl 2 axis foam cutter Eps Surfboard blanks Simple open concept but high production machine. Shape 3d case with open builds controller
Simpl3rBot
A framing design for cantilever style printers
Build Author Jason Moore Views 9602
Lead1500 Plasma Table w/THC
Denford CNC Resurrection
Denford CNC Mill Update
Build Author wackocrash5150 Views 16736
45W CO2 Laser Build
Y-1200 co2 laser
Y-1200 Build The Y-1200 has a cutting area of 1200 x 600mm and the main chassis has a external size of 1620 x 955 x 450mm. The recommended power output is 60-90W, this can also be increased with the use of an extension box. designed by furtherfabrication ROB CHESNEY FREELANCE INDUSTRIAL DESIGNER.
Monster-not-so-mini-mill
My Minimill hit the gym, and isn't so mini anymore
Custom 4x4 CNC
I started designing and ordering parts for this build back in Oct 2021. Unfortunately life got in the way and I had to sideline the project to deal with more important projects. I am now back working on this project full time. I originally was building a MPCNC on this torsion box platform I built but quickly realized how difficult it would be to produce anything with good accuracy. So I decided to design my own CNC that would be more robust and accurate.
KillerBee 1515 customized
Killerbee 1515 with modifications.
Build Author alex_b Views 16290
TACIT RONIN CNC - Flood Coolant Enabled C-Beam
The TACIT RONIN CNC is a fully enclosed C-Beam platform intended for flood coolant cutting of Carbon Fiber and G10 composites.
T Nut Holder for V Slot
This is a T Nut Holder for OpenBuilds V Slot System. Useful when you want to keep t nuts in place, for example when you're mounting something vertically.
Build Author Mark Carew Views 204229
OpenBuilds ACRO System
The OpenBuilds ACRO System was developed to be the most accurate and cost effective positioning system in its class. The ACRO System incorporates the OpenBuilds V-Slot system and, therefore, has the unique ability to expand to multiple sizes creating a size configuration custom to your needs. Choose the size that best fits your workshop. This versatile system allows for precise positioning of many different mountable tools and attachments.
