Zebu ( OX clone with Brasil materials)
Discussion in 'CNC Mills/Routers' started by skape, Nov 6, 2015.
  1. skape
    skape Well-Known
  2. Florian Bauereisen
    Hi,
    nice effort.
    One suggestion though:
    as you are using 2 plates on the side anyway: why not extend the shorter, and build up a complete box (close off all 4 sides) to strengthen the tall side Plate?
    Drill 2 holes into the second one to access your screws for the aluminum profiles...
    Doesn`t cost much, adds a lot of stability , which is neccessary with cnc.
    Well or at least tripple that long plate...
    btw i would loose some z (hight) - leverage always has to be counterd with beefing up that is why.
    good luck
    greets
    flo
  3. skape
    skape Well-Known
    Thx for the suggestions!
    I'm going with 2 plates because the of the witdth of the rail ( extructure + rail ) of +-7 cm, and never gave any thougth about raising it to the same lengt. but You planted an idea !
    In the moment I building X and Y axis prototype and use it with a laser so Z axis isn't planned yet. I'm thinking about the heigth beacuse the z carriege is in planning, and already metting some issues.
    Best regards (Freundliche Gruesse aus Brasilien)
    Skape
  4. pizzaman85
    this looks great cant wait to see it finished
  5. Josemar Santos
  6. skape
    skape Well-Known
    Fala Josemar!
    Obrigado, Fica ligado que o projeto está andando. Ontem montei uma parte da eletronica e alguns motores, e foi possivel fazer os primeiros movimentos.
    Sou de Curitiba e você?
  7. skape
    skape Well-Known
    Hi!
    Thanks for the likes and Yesterday I made a big leap in the project. The first "steps". A part of the eletronics and the motors is in place, and we were able to start the motors.
  8. pizzaman85
    do you have any dxf files of the plate, i am really interested in the way you are designing the machine, i have a bunch of the 80/20 lying around and the ox i put together just is not large enough and i do not want to tare it apart because it works great for the small stuff
  9. skape
    skape Well-Known
    Hi!
    I have the files that I sent for the cuting company ( dwg ) that I can send you, but if have time I would make some improvements from the lessons learned from building, ( f****** anoying to install and ajust the motors without access holes for the tools on the other plate. ) and then sent them to you.
  10. pizzaman85
  • About Us
  • Like us on Facebook
    Donate to FairShare!
