Yet another home/limit switch GRBL problem
Discussion in 'Control Software' started by JammyJulien, Apr 2, 2017.
  1. JammyJulien
    Hey all,
    I'm hoping for someone to give me some advice. I've build my own CNC machine which works well. Recently I decided to add home and limit switches, but I just cannot get them to work properly.
    I have been googling all morning and completed a lot of testing - but bCNC just brings up a homing alarm as soon as Z axis has homed (It's homed, and moved 5 mm off the homing switch). It doesnt appear the X and Y even tries to move.
    If I move any axis onto their home or limit switches, bCNC gives me limit alarms correctly.
    I have used 47uf capacitors connect to the home switches, which are wired as suggested on sites I have seen (I could try using 330 ohm resistors, but I have seen both used so guessed they are both suitable).
    I'm using GRBL 0.9j.
    As far as testing as gone, Ive set $10=255 and testing the switched. The ? Lim: settings reflect the status of the home and limit switches correctly (they are all wired in parallel). So all off in a normal state - and each switch pair reacts as expected.
    Any advice would be greatly appreciated, I can send pictures or explain the wiring in more detail if required.
    My GRBL settings are :
    Grbl 0.9j ['$' for help]
    $0=10 (step pulse, usec)
    $1=25 (step idle delay, msec)
    $2=0 (step port invert mask:00000000)
    $3=0 (dir port invert mask:00000000)
    $4=0 (step enable invert, bool)
    $5=0 (limit pins invert, bool)
    $6=0 (probe pin invert, bool)
    $10=255 (status report mask:11111111)
    $11=0.010 (junction deviation, mm)
    $12=0.002 (arc tolerance, mm)
    $13=0 (report inches, bool)
    $20=0 (soft limits, bool)
    $21=1 (hard limits, bool)
    $22=1 (homing cycle, bool)
    $23=3 (homing dir invert mask:00000011)
    $24=25.000 (homing feed, mm/min)
    $25=300.000 (homing seek, mm/min)
    $26=250 (homing debounce, msec)
    $27=3.000 (homing pull-off, mm)
    $100=50.000 (x, step/mm)
    $101=400.000 (y, step/mm)
    $102=400.000 (z, step/mm)
    $110=1900.000 (x max rate, mm/min)
    $111=300.000 (y max rate, mm/min)
    $112=300.000 (z max rate, mm/min)
    $120=100.000 (x accel, mm/sec^2)
    $121=10.000 (y accel, mm/sec^2)
    $122=10.000 (z accel, mm/sec^2)
    $130=500.000 (x max travel, mm)
    $131=500.000 (y max travel, mm)
    $132=140.000 (z max travel, mm)
    Thanks all,
    Jammy
  2. JammyJulien
    I've resolved this problem by creating a circuit as per attached picture.
    Rick 2.0 likes this.
  3. David the swarfer
    MaryD likes this.
  4. Rodm
    Rodm Well-Known
  5. Jim ford
    Jim ford New
    My laser machine is cutting backwards what do I do new at all this please help
    OpenBuildsCONTROL > Connect to your controller >
    Test jogging directions using jog buttons - note down any axis that does not comply with Cartesian Standards
    Grbl Settings tab > $3 Direction Invert > Flip the switch the opposite direction for any axis that needs inverting. Save and Reset when prompted
