Welcome to OpenBuilds Community
Signup today and join in on the fun!
Sign Up
Project Which Mill is best suited for small aluminum bowl?
Discussion in 'CNC Projects' started by levitation, Sep 8, 2017.
  1. levitation
    levitation New Builder
    I am making small aluminum bowls out of sliced aluminum rods. The Sketchup file is attached. I am considering the OpenBuilds mini mill which could cut the dimensions I am looking for, or modifying the C-Beam mill so that it has a larger z-axis travel.
    The inner bowl needs to be as smooth as possible.
    1. Can the mini mill do it?
    2. Which bits would I need to get the smoothest inner surface?
  2. Grantman
    Grantman Veteran Builder
    This job is better suited to a lathe than a mill.
  3. levitation
    Hi Grantman,
    Is it possible to get a smooth finish using the mini mill? The mill is more useful for upcoming projects even if a lathe is better suited for this one.
  4. Grantman
    No idea.
  5. MaryD
    MaryD OpenBuilds Team Staff Member Moderator Builder
    You may want to jump over to the OpenBuilds Facebook Group and connect with this guy. Making great progress in a week on a MiniMill. May have some insight to share.
