Vacuum Forming Machine
Discussion in 'Vacuum Forming Machines' started by rengelking, May 22, 2017.
  1. rengelking
    rengelking published a new build:
    TheArtman, Conco and FatGut like this.
  2. Giarc
    What is your heating element? This is a cool project. I am curious as to how strong the plastic is, too. I have some projects this would work well with.
  3. rengelking
    Thanks! It uses 2 of these heaters.. you have to carefully disassemble them, and rewire them; I was able to reuse the controls, but I disabled the thermal safety sensors, and also bypassed the over voltage cutoff. I have them set at half power. They work great because the heat is only absorbed by the plastic, with the aluminum reflecting most of it:
    Ecotronic 1500-Watt 2-Element Infrared Electric Portable Heater-TQH05 - The Home Depot
    Heika and Conco like this.
  4. rengelking
    Conco and Joe Santarsiero like this.
  5. Giarc
    Thanks fir the info.
  6. Anthony Bolgar
    Anthony Bolgar Journeyman
    Nicely done.
  7. Sonny Lowe
    Sonny Lowe Journeyman
    Thanks for the build and sharing your ideas, looks like it works great!!! I have a vacuum forming table already but lacked a heating source (not any more though :). I'll have too stop by Home Depot this weekend and see if they have any in stock, hell, they might even be on clearance...could I get so lucky!?!?
    Sonny
  8. Phil Ghobad
  9. Conco
    Conco New
    Please let me know the parts I need to buy and how to put it together. I need to make molds. This looks fantastic. Thank you so much.
  10. Heika
    Heika New
    This is a fantastic build. I happen to have one of those heaters sitting behind me as I type this. I really appreciate the video. If you have a moment, and can explain in more detail how you modified your heaters to do this project, I would be grateful. I can figure out the rest, but have never been much on electronics.
  11. Bubba Mouisa
    I found this interesting, I'm not much for plastics, but I'll most likely use this as a starting point to create a form molding machine for bending wood. I'll have to use high pressure air, rather than a vacuum draw though. But, this has given me food for thought, so Thank you.
  12. Bubba Mouisa
