V-slot and MDF DeltaBot
Discussion in '3D printers' started by mrtinkerer, Mar 17, 2015.
  1. mrtinkerer
    mrtinkerer Well-Known
    mrtinkerer published a new build:
  2. JustinTime
    JustinTime Master
    Nice looking printer! You got to love CNC machines that help you cut perfect parts to make other machines! :ROFL::ROFL:
  3. mrtinkerer
    I know. The v-slot fits perfectly in the MDF because of the CNC router. I don't think this build would have been possible for me without the CNC. I wanted to attach the g-code, but the site does not accept ngc files.
  4. Tweakie
    Tweakie OpenBuilds Team
    Excellent work with the DeltaBot @mrtinkerer :thumbsup:
    Tweakie.
    (if you change the file extension to .txt you can probably attach your Gcodes if you wish)
  5. mrtinkerer
    Good point with the txt. i will do that. thank you
  6. JustinTime
    JustinTime Master
    When I have a part I want to publish I don't post the g-code, I post the (in my case) SketchUp file. I may not have the same bit you used to cut the part. My bit may be smaller or bigger.
  7. mrtinkerer
    Good point. I build in CamBam. that has a .cb extension. Viewing the file with Notepad, I see
    <?xml version="1.0" encoding="utf-8"?>
    <CADFile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Version="0.9.8.0" Name="effector">
    followed by a bunch of coordinates and dimensions. So it looks like it is just an xml file. I could attach those with a txt extension and see if people can do anything with it.
  8. dave_robinson_022
    How did you find setting up and implementing dual extrusion on a delta printer as that is the main dilemma I am having over building one at the moment; I have the E3D legends pack....
  9. mrtinkerer
    I did not set up dual extrusion. I only have one hotend.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
