universal Gcode sender on raspberry PI?
Discussion in 'General Talk' started by gazingm42, Feb 14, 2017.
  1. gazingm42
    gazingm42 New
    Has anyone use the Raspberry pi to use the Universal Gcode sender. I am thinking designing my gcode in the house using sketchucam and send it to the raspberry pi in the garage will be a easy and cleaner solution. My wood shop is far from dust free. I have about 5 or 7 raspberry in the house from dogfood feeders to move controllers. I have a nice 10 inches monitor with the pi attached to the back. It would be a easy solution of the universal Gcode sender worked will
    on the PI.
    Thanks.
    Hi
    According to this web site
    UGS
    it will run on the Raspberry
    you just need to make sure Java is installed and then unzip UGS where you want it.
  3. gazingm42
    gazingm42 New
    Thank you David. I have java in my standard build I use in my pi os that I install. I give this a try.
  4. Clearcutter
    BCNC works great on the Pi
    it's what I run my machine with. I'm going to try it this weekend with the Pi 7" touchscreen
  5. John Meikrantz
    John Meikrantz Well-Known
