UltiFaker 2 Go
Discussion in '3D printers' started by PaulS, Feb 15, 2016.
  1. PaulS
    PaulS New
    PaulS published a new build:
    Looks like a good start. Can't wait to see how you fit the mechanics into the finished project.
    You mention Dibond being expensive but if you shop around, its really not that bad. A pack of 10 12x18 panels is only $55 on ebay or 24x48 panels on Amazon for $30. It might be interesting to start with a larger sheet and do a folded design of this project.
  3. PaulS
    PaulS New
    Thanks for the input Rick. I did come across some of these links but those are actually 1/8" thick panels. I needed the 1/4" which for whatever reason is either way more expensive or harder to come by. Usually the stuff I came across in 1/4" thickness came in the 4 ft x 8 ft sheets and I just didn't want to manage transporting or cutting something that big. However, I really like your score and fold idea.
  4. Rick 2.0
    I keep a standing search for Alucobest panels on Ebay to have them email me as soon as any pop up. A little over a year ago I scored seven of the silver 16 x 50 x 1/4 panels for $16 apiece (shipped). 80/20 puts their off-cuts out periodically and they generally don't last long.
  5. PaulS
    PaulS New
    I'll keep my eyes peeled. Thanks for the info!
    Thomas Hårklau likes this.
  6. Mark Carew
    Excellent build @PaulS you have done a great job at keeping cost down with what looks like it will be a great printer!
    Keep up the good work and thank you for sharing
  7. sjhilton
    sjhilton New
    Thanks Paul. I am very interested in your build and will be watching.
  8. Binary
    Binary New
    Double check the units on your chip load. I am assuming you are using a 3 flute (cutting blades).
    Feed Rate = Chip Load x RPM x Flutes
    .001 in x 16000 RPM x 3 = 48 in/min = 4 feet/min
  9. PaulS
    PaulS New
    Thanks for catching that. I meant in/min
  10. chris kelly
    I printed the top of the extruder and got 36mm is this correct?
