TRADE Trade? two power supply
Discussion in 'FREEStore' started by crazerico, Feb 27, 2017.
  1. crazerico
    crazerico New
    looking to trade for a spindle?
    or cnc parts
    what i have its two brand new power supply
    both came from
    alllieelectric
    Phoenix Contact - 2938604 - QUINT Series DIN Rail Mount Enclosed 85-264V In 24V@10A AC-DC Power Supply - Allied Electronics
    Sola/Hevi-Duty DC Power Supply, 24VDC, 20A, 47-63Hz SDN20-24-480CC | Zoro.com
    one is 48 volts 10 amps
    the other is 24 volts 10 amps
    close to $1000 or over for both i forgot lol
    if anyone have a use for those or any ?
    looking to trade they both are brand new sealed
    PM or make an offer here.
    Any by posting this i broke any rules please remove my post. i don't want to cause any problems :D
    thanks guy
    MaryD likes this.
  2. crazerico
    crazerico New
    forgot to mention i dont think anyone would want it i don't think.
    they can also include a ups controller and battery they are din rails.
    just in case u lose power your project doesn't go to wasted the ups and battery are used thought
  3. argelio
    argelio New
    do you still have 24 volts 10 amps p.s
  4. crazerico
    crazerico New
    Yes i still have both the sola 24 volts
    and phoenix 48 volts
    i posted wrong link on the phoenix
  5. crazerico
    crazerico New
    Adding more stuff as im cleaning the tool box out
    allen Bradley 1761-net-eni Ethernet interface module
    Ethernet Adaptor SLC-500 5vdc 470MA
    will have a full 8 slot rack with input output and all the goodies also if anyone is interested
    i figure i could trade then here if anyone got any hardcore project going on'
    looking for a turn key plasma setup
    if anyone interested in trading i have tons of automation stuff from Emerson,rosemount , fisher to deltaV stuff
    MaryD likes this.
  6. Tracy Ranson
    Tracy Ranson Well-Known
    Those are some amazing industrial grade power supplies that you have there. I don't need them, what I could use is some din rail need two 1 foot sections.
  7. stargeezer
    stargeezer Journeyman
    Hi, I've got a 1.5kw 4 bearing spindle and I believe a 2kw VFD, Both used about 2 months, mostly to check out the build, while I waited a bigger spindle. I also have a bunch of automation goodies to trade too, some 20mm hardened rods lots of 20mm linear bearings, mounts, etc.
    I could sure use the Phoenix 24v supply depending on the input voltage (I can only use 120-240) and like others, some din rail is always needed.
    I'm working on a 60"x 60" plasma cutter right now, but it's not for sale yet. :)
    If interested, drop me a PM with a phone number, or I can send you mine.
