Touchsensor assembly machine
Discussion in 'Other Builds' started by Jan Koeppen, Apr 22, 2016.
  1. Jan Koeppen
    Jan Koeppen Well-Known
    Jan Koeppen published a new build:
    Giarc likes this.
  2. Mark Carew
    Wow @Jan Koeppen this is exactly what OpenBuilds parts were designed to do!
    Can I ask what you are using for control?
    Thank you first for sharing this and for the OpenBuilds credit in the video very cool :thumbsup:
  3. Jan Koeppen
    We use MK3/4 from PlanetCNC.
    We prepared 3 SD Cards, so we can use it without external PC. One for Homing and two for the different application programs.
    #3 Jan Koeppen, Apr 23, 2016
  4. Jan Koeppen
  5. Mark Carew
    This is a very nice setup!
  6. Joep
    Joep New
    Could you tell us which suction cups you used?
  7. Einar
    Einar New
  8. Trevor Toenjes
    What did you use for the air compressor/hoses/fittings and controller for the valve?
    I want to create a similar system to sort a stack of different thicknesses of glass.
    thanks.
  9. Einar
    Einar New
    Hi Trevor,
    to create the vacuum, we use a vacuum pump with a pressure reservoir. It's not a special one, just a pump we had here. But there are several other possibilities to create vacuum, even with compressed air (But it's loud and expensive in usage).
    Hoses are standard-hoses (e. g. Luftschläuche/Standard|MISUMI|MISUMI) We have no problems with -0,9 bar with these hoses.
    Fittings are standard fittings, too. Just these blue plug-in-connectors. (e. g. Suchen nach Schnellkupplungen Artikeln und vielen anderen industriellen Komponenten |MISUMI
    The valve should be for vacuum use. It is controlled by the controller PCB, switched by a relay. (The controller PCB only provides 5 V and the valve need 24 V)
    Hope I could help you. Have a nice day.
    Greetz
  • About Us
  • Like us on Facebook
    Donate to FairShare!
