Tear down of Cubify cube 3 3D Printer + convert to RepRap
Discussion in '3D printers' started by Oderbang, Dec 6, 2015.
  1. eychei
    eychei Veteran
    is this xml file on the sdcard?
  2. Tom Dirriwachter
    I would suspect so, I doubt this would be reliable enough to rely on the internet to confirm.
    We still don't have the installed content of the internal SD uploaded anywhere.
  3. eychei
    eychei Veteran
    Okey I did check the SD Card of my CubePro and there is no such xml file.
    I did upload the SD Card Files.
    There is nothing to see in there:(
    edit:
    I cant upload the file as attachment. Did try to change the extension to txt but still no luck.
  4. JustinTime
    JustinTime Master
    @eychei, did you try to upload it as a .zip file?
  5. eychei
    eychei Veteran
    Yes it is a zip file. I tried uploading as zip.
  6. Daniel Kuecker
    I have purchased the RAMPS 1.4. I was wondering if you could help me. How do I wire the stepper motors? They are different than the ones I see in videos as they have 6 pin connector. I assume I need to wire the 4 wires to the ramps board, but I do not know which wire goes where . Also, how about end stops? Does this have end stops to wire to the ramps board?
  7. eychei
    eychei Veteran
    Ok the xml file which was mentioned is on the cubify server.
    This is called when starting cube print.
    Private Const Cubify_Version_XML As String = "http://cubify.s3.amazonaws.com/public/cube3/magellan_software.xml"
    I did find something else.
    The config files in the cubify folder are encrypted. The scrambled password is : eXbfXoDj^e\\>?/12
    AND this is the unscrambled one:)
    221BBablfsNzdspgu
    The files are encrypted with blowfish. Maybe someone can find out how to decrypt them.
    There is a file in the cubify folder which is named cubefyit.exe . This loads the file ConfigurationCube123.xml which then is used for configuration of the printer.
    If someone wants to look into the code. I have attached it.
    Kiza likes this.
  8. Tom Dirriwachter
    That looks like the internal version of the 4.03 windows software.
    When you put the x.cube3 file on a memory stick, the internal processor does a lot of processing.
    When you send it over WiFi, it is much faster, so there is a difference in the way you interface with the system.
  9. Kiza
    Kiza Journeyman
    That's not the unscrambled password ^_^. Working on decryption, I will post whenever there is a result :)
  10. Geezer70
    Geezer70 Journeyman
    221BBakerMycroft
    Kiza likes this.
  11. Tom Dirriwachter
  12. Kiza
    Kiza Journeyman
    Good :) But so far I could not decode for some reason, decode function has a strange behavior. It does not decode more than 30 bytes at a time no matter what length you will specify. And mostly it complains about the length itself. Will try more tomorrow.
  13. eychei
    eychei Veteran
    OHHH TOM you made my Day.
    Just use CubeX to decode the files!!! It works:
    <?xml version="1.0" encoding="utf-8"?>
    <Config xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="XML Schema">
    <global>
    <ConfigurationFileVersion>X560</ConfigurationFileVersion>
    <m_ModelColor>
    <red>0</red>
    <green>204</green>
    <blue>255</blue>
    </m_ModelColor>
    <m_BkgrndColor>
    <red>201</red>
    <green>211</green>
    <blue>226</blue>
    </m_BkgrndColor>
    <Model>CUBE3</Model>
    <Material>PLA</Material>
    <NetworkName />
    <NetworkKey />
    <Cube3Support>true</Cube3Support>
    <NewComp>true</NewComp>
    <ModelColor>
    <red>0</red>
    <green>204</green>
    <blue>255</blue>
    </ModelColor>
    <BkgrndColor>
    <red>201</red>
    <green>211</green>
    <blue>226</blue>
    </BkgrndColor>....
    Kiza likes this.
  14. Naldarn
    Naldarn Journeyman
    BUT HOW???
  15. eychei
    eychei Veteran
    Start CubeX64 or X32. Choose Cubepro and decode.
    Go to browse and Choose all Files in filetype.
    Go to cubify dir and pick config123.xml and Press ok. File will be named *.bfb. Open with notepad.
  16. Naldarn
    Naldarn Journeyman
    This software or another? The only CubeX software I can find.
    #406 Naldarn, Jan 11, 2017
  17. Tom Dirriwachter
    Any switches in there for DIAGNOSTIC MODE, ADMIN MODE, DISABLE XXX?
    If anything, this is exactly where you'd put diagnostic switches that could include the security chip.
    Once you know that switch, we can probably add it to another config file.
    If all this handshaking is going on with Cubify, how do you force a local XML file to take precedence?
  18. Naldarn
    Naldarn Journeyman
    I was able to use a program called Fiddler, worked in a few minutes to host the magellan_software.xml on my pc
    #408 Naldarn, Jan 11, 2017
  19. Naldarn
    Naldarn Journeyman
    Ok, found an interesting dialog from the cube print software, here is the request and response. Can anyone make sense of it?
  20. Tom Dirriwachter
    That looks like an ad-hoc network connection with encryption request.
    Mine will connect to a neighbor's protected router and consider itself connected but not be found on my network.
    This is what I mean about persistence.
  21. RobertW
    RobertW Journeyman
  22. eychei
    eychei Veteran
    @Naldarn
    The Software cubeX was mentioned by Tom Dirriwachter .
    I looked into the XML Files but couldnt find any references to a admin / debug mode.
  23. eychei
    eychei Veteran
  24. Naldarn
    Naldarn Journeyman
  25. Naldarn
    Naldarn Journeyman
    My closest neighbor is a mile away, so no other networks around here.
  26. eychei
    eychei Veteran
    Oh sorry. I mean codeX
  27. Naldarn
    Naldarn Journeyman
  28. Naldarn
    Naldarn Journeyman
    @As a standalone project, a prebuilt project, or library project?@
  29. Kiza
    Kiza Journeyman
    Finally had a look on our *.ar files. Appeared to be pretty straight-forward, no checksums, only sizes of files plus overal size and couple of signatures in the begining.
    That means once we modify our *.hex file, there will be no problem putting it back to printer.
    Here is my small tool for firmware un-pack/pack (sorry, very raw, must be very buggy, change extension to exe and have framework 4.5 installed).
    P.S. Just tried to upgrade from my re-packed firmware, it worked, printer is not bricked! Whohooo :)
    Disclaimer: Everything you do to your printer, you do on your own risk :)
    #419 Kiza, Jan 12, 2017
  30. Naldarn
    Naldarn Journeyman
    Great!! Any idea what the mrl files are? I think they are for the lcd display, but can't find any way to view them.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
