TB6600 and xPro on OX
Discussion in 'Controller Boards' started by andrew Adsit, Aug 12, 2015.
  1. andrew Adsit
    andrew Adsit Well-Known
    My initial build used the xPro V2 and I love the form factor and virtually everything about the all in one driver. But I did experience many of the trials of setup for getting the current setting right. With all the tweaking and micro stepping set, I still got rough movement when cutting hard material - had to slow the feed rate down which I think contributed to the problem.
    Decided to experiment with a Chinese TB6600 4 axis board and I know all the negative warnings, but I thought it would be worth a try. Got it in, set the current dip switches, and connected to an eBay old Dell computer running XP. Runs super smooth and required no tweaking. The board appears to be well made with good solder joints. For $50, it was worth a look. Will probably buy a spare, just in case.
    My first choice was the Gecko 540, just couldn't justify the price just to see if I needed more current.
    I have my TB6600 set for 3.2 amps on my NEMA 23s that are rated at 2.8. Any experience with the Chinese TB6600 boards?
    UPDATE: see below. Abandoned the TB660 4-axis board as one of the Y channels started acting up. Now using Gecko G540.
    #1 andrew Adsit, Aug 12, 2015
    Joe Santarsiero likes this.
  2. andrew Adsit
  3. andrew Adsit
    OK, an update. My OX with the TB6600 control board and Mach3 is running awesome. I have added an old XBOX 360 wired USB game control and customized to do jog, rewind my build, zero my z, and a whole bunch more. I have also made a z-zero block and my Mach3 will zero z using it making tool change super simple. I have uploaded the plate to Thingiverse, but working on a thinner version.
    http://www.thingiverse.com/thing:967987
    Quick Youtube video:
  4. rcKeith
    rcKeith Well-Known
    Hi Andrew
    I've been using a TB6560 on my 4 axis hot wire foam cutter for some time now and never had an issue with it. I think the key is to make sure everything runs nice a free so you don't overload the motor. Will be buying an OX soon and plan to use it to control that as well. I built the foam cutter so its connected to controller board by RJ-45 LAN cables going into wall sockects mounted on the machine and controller. That was I can dismantle when not in use, don't have a lot of space. Some pics on my website http://www.rckeith.co.uk/cnc-hot-wire-foam-cutter/
  5. andrew Adsit
    I am gaining respect for Mach3 as well. I struggled with the controller software (freeware) and it is so much better when you have supported s/w. Tool change much easier, touching off works, and starting in the middle of a program is possible. Happy builder!
  6. andrew Adsit
    Absolutely. Was careful to raise z to safe height or I think that would have happened. I am amazed that "go to zero" doesn't raise the z first, then x and y.
  7. andrew Adsit
    Another update. After several awesome cuts using the $54 Chinese TB6600 4 axis controller board, I started to get interminent failure on one of the y drivers. Needless to say, the cuts were a complete fail. I tied both ys to the single operating y axis drive and upper the current to the max, and the OX worked fine, but would blow a poly fuse about 12-15 mins into a cut.
    Laid my pride aside and purchased a Gecko G540 and it is working great. No missed steps, no grinding noises. No jagged curves. I highly recommend. Cutting at 170% speed appears to be fine (25mm per second) in soft wood. Happy me.
    Final tool chain: Vectric V-Carve Pro, Mach3, Gecko G540, OX with 4 NEMA 23 steppers on a 750mm x 750mm bed. Xbox controller pendant. Effective cutting area approximately 550mm x 550mm.
    Next phase, get the electronics in a nice Bud Box, rewire steppers with 18-4 shielded cables, rewire end stops with 22-2 shielded wire.
  8. andrew Adsit
  9. JOSEPH WYNNE
    JOSEPH WYNNE Well-Known
    Hi Andrew, You may be my life-saver: I too have bought a TB6600 4 axis with nema 23/17 motors and Mach3 software for my OX Build: Having trouble setting up the electronics-- wiring, pins, etc... Can you advise? I am extremely new at this!
