spindle motor specs for milling 6000 series aluminum
Discussion in 'CNC Mills/Routers' started by mayur, Aug 13, 2017.
  1. mayur
    mayur New
    I was planning to make a cnc mill for milling 6000 series aluminum. so can anyone tell me what kind and specs of spindle motor should i look for so that the milling process becomes smooth without any lack of power or torque. Also please recommend the stepper motor that i should use for the movement of spindle.
    Thanks !!
  2. Kyo
    Kyo Master
    I cut 6061 plates for misc. projects using this Dewalt trim router. It has been holding up well. I am planning on running this 1.5Kw spindle next. If I was to start over, I would just start with the spindle up front as it is only a slightly higher cost compared to my Dewalt and Precise bits collets set.
    For the stepper to lift the Z-axis / spindle. I have run both Nema 23 motors available in the Openbuilds part store. Both work great. I prefer the High torque motor they sale Here.
    Joe Santarsiero likes this.
  3. mayur
    mayur New
    Thanks so much kyo !!
    Can you also please tell me how you power those steppers ?
    Do you use some kind of relays ?
  • About Us
  • Like us on Facebook
    Donate to FairShare!
