Soundproof case for Ox
Discussion in 'CNC Mills/Routers' started by pocovolvedor, Mar 28, 2017.
  1. pocovolvedor
    pocovolvedor Well-Known
    pocovolvedor published a new build:
  2. fos4o
    fos4o Well-Known
    Hi
    What is the black and white material on the inside of the box?
  3. JustinTime
    JustinTime Master
    The black and white material looks like carpet underlay foam to me! :ROFL:
    pocovolvedor, did you give some thoughts to the option to connect a vacuum dust extruder to this box?
    Joe Santarsiero likes this.
  4. Joe Santarsiero
    Joe Santarsiero OB addict
    and the box to put that in :)
  5. pocovolvedor
    Hello
    Is a material called "copopren" http://www.leroymerlin.es/fp/15999312/panel-de-aislamiento-acustico-copopren-ca80-2000x1000x40mm-ign
    Here in Spain we use it to insulate walls. Its cheap and is very effective. Check for similar materials on a construction market near you...They must have something similar to this...
    Or you can go pro and use some especific insulation material matching the mid and high frequencies that your routers do.
    All insulations have a frequency range you must search something to reduce the 1000hz to 20000 hz range if its possible...This routers dont make to much low frequency noise...
  6. pocovolvedor
    Hello,
    I think you can use something like this attached to the router box.
    Try to avoid the direct to exterior big holes...
  7. Joe Santarsiero
    Personally, I,d be worried about a fire or worse a dust explosion.
  8. fos4o
    fos4o Well-Known
    Thanks a lot :)
    I'll try to make the box and see how it will come up.
  9. pocovolvedor
    You can use a cyclonic separator but I dont know if they are explosionproof
  • About Us
  • Like us on Facebook
    Donate to FairShare!
