Prusa i3 (Acrylic frame with OB rods)
Discussion in '3D printers' started by dddman, Feb 6, 2015.
  1. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Looking real good Robert. :thumbsup:
    Tweakie.
  2. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    Ty :)
    I did calibration lastnight and printed it's first part along with a test of the heatbed.
    It takes 5 mins to get to temp and a blast with my infrared gun showed even temps :thumbsup:
    I must say I really like this printer :D
    #32 Robert Hummel, Mar 24, 2015
    Mopar32985 likes this.
  3. dddman
    dddman Journeyman
    Yes, yes and yes.
    Robert Hummel likes this.
  4. dddman
    dddman Journeyman
    The source of many problem can be found with simply a picture of a print and the first layer of that print. By the way, we will upload the working Marlin code for that printer soon (just have to talk to robert first :p )
  5. Robert Hummel
    Moderator
  6. Robert Hummel
    Moderator
    So I figured I would put the OBi3 to the test and see just what it could pull off :)
    .1 layer 12.5 micron resolution :D
    Then I said hey why not try it at 50% scale ;)
    Then I figured what the heck 25% should be interesting o_O
    :thumbsup: Not bad for a .3 nozzle
  7. Tweakie
    Moderator
    Brilliant :D:D:D
    Tweakie.
  8. dddman
    dddman Journeyman
    ABS sucks :p
  9. Robert Hummel
    Moderator
    Yes all my prints are PLA :)
    I will be trying ABS but I hear it smells
    The micron level is determined by your pulleys, belts and micro stepping
    I have gt2 belts, 20 tooth pulleys and running @ 1/16th step rate the calculator is part of the prusa caluculator online :)
  10. Robert Hummel
    Moderator
    The tape goes right onto the glass no treatment needed and prints stick good.
    Green painters tape is a gamble some works some don't :/
  11. Mopar32985
    Mopar32985 Well-Known
    so i was looking at the BOB and i saw there was 3/8 threaded rod isnt there 2 different sizes used
  12. Robert Hummel
    Moderator
    The parts you printed are designed for M10 in the y direction and M8 X direction
  13. Mopar32985
    ok sounds good i know you told me on instagram but cant find post what legths do i need of each again sorry haha about to order rod lowes only has 8m threaded rod no m10. Also what size bearings dont see them on the list aswell
  14. Robert Hummel
    Moderator
    OBi3 kit with assembled Wades minus the hotend getting packed for shipping :D
    On to a custom themed one ;)
  15. Robert Hummel
    Moderator
    One meter of each ;)
  16. Robert Hummel
    Moderator
    And now for a ABS test print :nailbite:
  17. Mopar32985
    Thanks bud will order them. Also i have the standard skateboard bearing size for extruder but i know i need smaller ones do you know what size
  18. Robert Hummel
    Moderator
    2x625z for Y
    1x624z for X
    In my kits I use 3x625 OB bearings because I have 5mm to 3mm inserts ;)
  19. Mopar32985
    Great man thanks i appreciate it!!
  20. Mopar32985
    Man i was just looking at the parts in the file section these parts are wrong im holding the y motor mount and it has holes for 10mm rods where the corners have holes for 8mm. Same is true with y belt tensioner Also even if they were 8mm they dont line up with the corner blocks
  21. Robert Hummel
    Moderator
    I will put the stls together now, give me 30 min :)
    Sorry bud not sure what happened there
  22. Mopar32985
    no worries man all parts wont be in until friday. Thanks man
  23. Robert Hummel
    Moderator
    Here you go bud, I think you got a mix of the orig and my modded version stls o_O
    • OBi3.zip
      File size:
      950.9 KB
      127
  24. Mopar32985
    I just grabbed all the separate files under the file tab. Should those be the only 2 parts that are different. Thats all i can tell.
  25. dddman
    dddman Journeyman
    3/8" rods are 9.525mm, good enough for what they are used for in this build and much easier to find
  26. Robert Hummel
    Moderator
    I don't use any supports but do use BLUE painters tape and a 5mm brim to create more surface area for the bed to hold onto.
    With the proper cooling overhangs will be improved greatly
    JustinTime likes this.
  27. Mopar32985
  28. OgreMills
    OgreMills New
    Where/what is the name of the part that attaches to the X Idler and X Motor mounts that the threaded rod goes through? I don't see it in the files section.
  29. Mopar32985
    Im not 100% sure of the name but download the file the robert share bottom of second page. I just open up the parts in an stl viewer like netfabb
  30. OgreMills
    OgreMills New
    I looked through them all but I don't see that part. I'm starting to think is a metal part that gets attached to the X idler and motor parts instead of inserting a nut as some of the other build use. I'd just like clarification on it before I print the parts.
    This black part is the one I'm seeking more info on.
    #60 OgreMills, Apr 2, 2015
