Pot Plotter
Discussion in 'DrawBots' started by Anglesachse, May 24, 2015.
  1. Anglesachse
    Anglesachse Well-Known
  2. Tweakie
    Tweakie OpenBuilds Team
    Thanks for sharing this excellent build @Anglesachse :thumbsup:
    Tweakie.
  3. John Robert
    Hi
    Could this be addapted to laser engrave a pen?
  4. Anthony Bolgar
    You should be able to adapt it, instead of using a servo to move the pen up and down, replace it with a pwm controlled laser diode. Not sure if this machine would have the resolution and accuracy to do fine engraving on a small diameter pen though.
  5. John Robert
    Thanks for your reply. I was thinking of useing the basic frame but use a lead screw instead and as you suggested a laser, I belive Bangood do some reasonable low powered units.
    The only way to find out is to build it and see :)
    Anthony Bolgar likes this.
  6. Anthony Bolgar
    That's the way I approach things as well, there is no failure available, only opportunities to learn how not to do something:)
