Pocket cutting with a large bit
Discussion in 'OpenBuilds Forum Help' started by jbell, Sep 16, 2017.
  1. jbell
    jbell Well-Known
    I'm cutting out the inside of a spoon 11/4" X 21/2". I'm using a 3/4" bowl router bit which will give the spoon nice rounded edges. The problem is the cut goes outside the perimeter in a couple of places.
    The rectangle works but at the bottom the lines go wider then the rectangle which causes the cut to go too wide. I've viewed the video on the pocket tool but haven't found a solution. When I use a 3/16 ball bit it works great.
  2. JustinTime
    JustinTime Master
    I too have sometimes problems with the pocket tools and when that happens I just fix the problematic spots manually. You may have to 'explode' the pocket lines since they are continuous. You'll see what I mean when you'll try to make changes to it.
