PhlatPrinter MK 3
Discussion in 'CNC Mills/Routers' started by Mark Carew, Jun 15, 2017.
  1. Mark Carew
    Mark Carew published a new build:
    Tashadra likes this.
  2. Tashadra
    Tashadra Well-Known
    Thanks for posting this build.
  3. 3DMON
    3DMON Journeyman
    Mine is still getting used and working good 6 yrs later...
    Mark Carew and MaryD like this.
  4. Mark Carew
    That is just awesome to hear guys! I have mine as well and am in the middle of a controller upgrade. :)
    So cool to have this up here on OpenBuilds. Thanks for the support Phlatboyz! :thumbsup:
    3DMON likes this.
  5. Nor Idzuwan Bin Mohammad
    Thank you for posting the build and files mark! has anyone build mk3 with laser yet? :D
    #5 Nor Idzuwan Bin Mohammad, Jul 2, 2017
  6. SlowBipe
    SlowBipe Well-Known
    I love the Phlatprinter mk3. I have been using mine for 5+ years. It has run for close to 1000 hours. I've gone through 4 or 5 roller drive belts. My original controller was used with LinuxCNC but the Y axis failed on it last week. Replaced it with a CNC XPro V3 controller and was up running again in about 3 hours. I can't believe how much smoother it runs with the new controller. I can cut 1/4 inch foam at up to 400 inches per minutes without any problems. Parts just fly off the machine.
    I added a pneumatic lift for the top roller arm. Best upgrade you can make. I flip a switch, slide a new sheet of foam in, switch again to drop the arms and send the code again.
    What a great design Mark. Thanks for all of the hard work. I'll try and post some pics later of the pneumatic lift mechanism.
    I have built a 1500 x 1000 modified OX which I love, but this is my go to machine for sheet foam. It's just so fast to change sheets. I also love the CNC XPro V3 controller. Can't believe how easy it was to get it running.
