OX 1000mm Y Axis Upgrade
Discussion in 'CNC Mills/Routers' started by andrew Adsit, Dec 13, 2015.
  1. andrew Adsit
  2. Giarc
    You mentioned you strengthened the X axis. What did you use?
  3. andrew Adsit
    I drilled thru one rail and tapped the other and screwed them together at 2 points about 1/3 in. Very sturdy.
  4. Giarc
    Thanks. I am still tossing ideas around in my head on how to make my x axis.
  5. leversole
    leversole New
    I am going to drill mine also...it appears that the only flex is coming from movement between the two x rails...bolting them together should increase the stiffness
