Original PhlatPrinter
Discussion in 'CNC Mills/Routers' started by Mark Carew, Nov 8, 2013.
  1. 3DMON
    3DMON New
    Your making good progress.
    The rods are steel going into bronze bushings and are held on with lock collars. Hopefully these pics will help you.
    #91 3DMON, Oct 25, 2016
    Mark Carew and David the swarfer like this.
  2. Angelobf
    Angelobf New
    Olá 3DMON
    Agradeço o elogio, eu estou tentando ser o mais fiel ao projeto original, embora pouca informação de sucesso.
    Como eu entendi e preso o eixo de aço, será difícil fazer um pensamento bronze bushing'm e eu uso 4 rolamentos Foto Igualdade.
    Eu tenho uma pergunta que você sabe dizer-me o diâmetro das duas hastes.
    Outra dúvida e os dois rolos inferiores são de aço? Sabe informar o diâmetro interno e externo deles ainda não sei como eles ainda ver o desenho ta aparecendo um erro que eu não sei onde isso.
    Desculpe tantas perguntas. Obrigado
    1 2 3 4 5 6 7 8 9 10 Mais
  3. Angelobf
    Angelobf New
    hello 3DMON
    I appreciate the compliment, I'm trying to be as faithful as I can to the original design, even with limited information obtained
    I understood how and stuck the steel shaft, it will be difficult to make a bronze bushing'm thinking of using 4 bearings with rolling as the photo.
    I have a question, you can tell me the diameter of two rods that go on top of the rolls.
    Another question and the two lower rollers are made of steel? Knows inform the internal and external diameter of them still do not know how to make them, by drawing in sketchup ta giving a measurement error, this stranger.
    Sorry so many questions. Thank you
  4. 3DMON
    3DMON New
    The top steel rods on mine measure 15.5mm diameter but I think the original came with 5/8".
    The bottom rollers are 2" diameter steel pipe but have a 1/2" steel rod in the middle.
  5. Angelobf
    Angelobf New
    hello 3DMON, synchronized pulley that has in large rolls down has how many teeth can tell?
  6. matt_o_70
    matt_o_70 New
    What is the shaft diameter that the U bearing rides against? For example If you google "SG15" you will find there is a series of U Groove bearings in various sizes. SG10, SG15, SG20, SG25 etc..
    for example It looks like the SG15 bearing rides on a 6mm Shaft.
    #96 matt_o_70, Oct 26, 2016
  7. 3DMON
    3DMON New
    I do not know how many teeth they are and it would require me to take it all apart to find out. Maybe Mark would have that answer for you.
  8. Angelobf
    Angelobf New
    Thank you all the help and welcome
  9. Angelobf
    Angelobf New
    Mark, time does not respond, since I sent up email to him but nothing, but I will keep trying. Thank you
  10. Mark Carew
    Hey guys following along :) great work on this build @Angelobf so far.
    Its been a while since I have put one of these together :) I will try to help out where I can
    I can say on the bearings I no longer have the info.
    *The 2 drive roller pulleys are from Stock drive products - A 6M16-060DF2508
    Product | Designatronics Store | Stock Drive Products/Sterling Instrument
    *Belt used - A 6B16-155025
    *Rods 6mm from mcmaster - McMaster-Carr
    Hope this helps to point you in the right direction.
    Mark
  11. Angelobf
    Angelobf New
    Thank you Mark, helped a lot whenever you have doubts ask the friends of the forum, the 3DMom has helped me a lot and I am grateful.
  12. Mark Carew
    More then welcome my friend. I'm loving watching the Build come together. It brings back so many memories :)
    @3DMON is one of the good ones. He has a lot of experience and will never steer you wrong.
    Keep up the great work. This is awesome! :thumbsup:
    Angelobf and 3DMON like this.
  13. Angelobf
    Angelobf New
    Hello mounting of the lower rolls and I have a question, what is the distance between the roller and the Phlat table? I put a drawing to guide.
    Another measure that can not be found in the assembly and 3/16 between the rollers.
  14. Mark Carew
    I have .2372" between the rollers and .1155" from the top of the driver rollers to the top surface of the table.
  15. Angelobf
    Angelobf New
    Hello mark you have drawings equal to this assembly
  16. Giarc
    I am curious how well this would work, if at all, to feed 5 mm plywood through to cut hull pieces for stitch and glue canoes/kayaks. It would be a compact way of cutting long narrow sheets.
  17. Angelobf
    Angelobf New
    Hello Mark Carew, sorry the translator translated her name wrong
  18. Mark Carew
    I see no reason why not. I once did an 8' x 2" thick Phlatboyz foam sign. You may need to add a layer of foam under the play to assure a good grip.
    Just the assembly in the Zip here
  19. Giarc
    Thanks for the answers guys.
  20. Angelobf
    Angelobf New
    Hello, Does anyone have the drawing in SketchUp to use pen 1 drawing of the right of the attached drawing, to be exported to Cad to have cut in cnc
  21. 3DMON
    3DMON New
    I'm confused to what your asking. From the pic you posted it looks like you already have it.
  22. Angelobf
    Angelobf New
    Hello Justin Time, this same you commented this and an image, wanted to see if someone or Mark has this file to provide, I tried to send a private message to the mark but it was not the error.
  23. Angelobf
    Angelobf New
    Hello 3DEMON, the file and just an image I do not have the drawing in SketchUp.
  24. 3DMON
    3DMON New
    Just disassemble it within Sketchup and lay the parts flat. That is all that was done with the rest of the parts in the sketchup file.
    3d....mon
  25. Angelobf
    Angelobf New
    Hello 3DMON, I tried to do this but I could not, quit everything and gave up. Can you help me?
  26. 3DMON
    3DMON New
    Yes I can.
  27. 3DMON
    3DMON New
    Ok Angelo,
    I added it to the original Sketchup file under the other attachments. I hope that helps.
  28. Angelobf
    Angelobf New
    Hello 3DMON, thank you very much helped me, I will move to the Cad and cut.
  29. 3DMON
    3DMON New
    Your welcome.
  30. Mark Carew
    Hey guys Phlatprinter 3 has been added to OpenBuilds :)
    Have fun!
    PhlatPrinter MK 3
