OpenRail Gantry Plates and Vslot
Discussion in 'CNC Mills/Routers' started by Jestah, Jan 10, 2014.
  1. Jestah
    Jestah Well-Known
    Hi Guys,
    This might be a total noob question but can I use the OpenRail Gantry plates to interface to Vslot?
  2. Mark Carew
    Hi @Jestah
    If you attach the OpenRail to V-Slot you can use the OpenRail plates on it then. This is because the hole spacing is different on the OpenRail plates compared to the V-Slot gantry plates.
    Hope this helps
  3. Jestah
    Jestah Well-Known
    Hi @kram242
    thanks for that heads up... is the only Vslot plate the universal one? Would I have to fab my own smaller ones if I wanted a range like the openrail set?
    Also on a side note did you get my message on the parts store regarding my account?
  4. Mark Carew
    The OpenRail plates will work with the OpenRail sizes from the size they are down. So for instance if you get the 60 size plate it will work on the 60,40,20 the 20 size will only work on the 20 because it is the smallest available size. So they are sorta universal a little :)
    The V-Slot gantry plate hole pattern will work with all sizes of V-Slot from 20x20 through to 20x80.
    We did and we will be working on that tomorrow and will get back to you asap. Thank you
  5. Jestah
    Jestah Well-Known
    Thanks so much for that info!
  6. Mark Carew
    Welcome :)
