OpenBuilds C-beam 15mm belt on 1500mm C-Beam.
Discussion in 'CNC Mills/Routers' started by Dave420, May 18, 2016.
  1. Dave420
    Dave420 Well-Known
    BigBoyztoyz likes this.
  2. Carl Feniak
    Carl Feniak Master
    Are you using two mini V wheels per side? If so, what size spacer are you using between them?
  3. Dave420
    Dave420 Well-Known
    Yes I'm using 12 x Solid V Wheel 2 per axial. not nini's I used the 9mm spacers
    #3 Dave420, Jun 10, 2016
  4. Tom O'Donnell
    Tom O'Donnell Well-Known
    I like the idea of a belt drive. I had a Harley with a chain and a belt drive. The belt drive was great. I'm still a little concerned about the strength of a smaller belt over time. What size motor will you use? Any thoughts screw vs belt?
    I'm still looking at other builds as I have not determined what size I want to build. I will probably build about a 12" x 24" to cut wood and aluminum.
    Thanks for any help you might have, Tom
    BigBoyztoyz and Dave420 like this.
  5. Dave420
    Dave420 Well-Known
    1500mm screw drive is pricey & I don't see anyone selling a 1500mm x 8mm screw drive. The
    HTD 5M PU 15mm wide belts I'm using have 6 to 8 stainless steel cables inside polyurethane belt. not plastic, vinyl or rubber. I'm using 279oz SureStep NEMA 23's to start. I just welded the 5x10 ft table today. so it has not bin tested. I can always buy stronger NEMA's if i need to. I am also using the same Nema's on my dull X Axis and the same 15mm belt.
    #5 Dave420, Jun 14, 2016
  6. Dave420
    Dave420 Well-Known
  7. Tom O'Donnell
    Thanks for this info. It is what I'm looking for - Tom
    Dave420 likes this.
  8. C-Line
    C-Line New
    Any updates on this build? How did the 15mm belt perform in terms of stretch, accuracy, repeatability and wear? Any issues with slippage on the pulleys? I'm considering something similar and would be curious to know your results.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
