Ooznest OX, Workbench, & Folding Table
Discussion in 'CNC Mills/Routers' started by Silverrabbit2, Dec 3, 2016.
  1. Silverrabbit2
    Silverrabbit2 published a new build:
    Gunnar Norum likes this.
  2. Giarc
    I almost used one of those Husky tool chests for mine as well, but I wanted something a little wider. I had considered two back to back, but chose another method. For your folding version, the Huskey is brilliant.
  3. Silverrabbit2
    Thanks for your kind words.
    I needed portability & storage of tools.
    I was going modular until...
    I saw an old luthier table carver that tilted 45 deg for storage.
    I thought, why not 90 deg with a piano hinge.
    It fits thru a doorway. My goal was met.
    Jose A. Molina likes this.
  4. Joe Santarsiero
    Joe Santarsiero OB addict
  5. Giarc
    I am so glad I read your post. I am planning to build a small shop and put my CNC in sometime in the near future. I completely forgot about getting it through the door. May have to build the shop around it.:eek: I could disassemble, but that would be a lot of work. Or, maybe I will go with a double door. :thumbsup:
  6. Rick 2.0
    So when it's too cold in the garage you can move it into the living room. Sweet!!!! :thumbsup:
    Joe Santarsiero and GrayUK like this.
  7. GrayUK
    It gets tricky, using a CNC, and watching TV in the lounge! :D
  8. Jose A. Molina
    Jose A. Molina Well-Known
    This would make a great tool for schools where the classroom can change or not have adequate ventilation so it can go out to the room or parking lot and back into storage.
    GrayUK likes this.
  9. Daniel Harbin
    What about accuracy and alignment when the machine is folded or unfolded. I could see misalignment problems
  10. Ankur Bohra
    is this machine capable for machining on aluminium???
    if yes then...Can i get the CAD files please...???
    accuracy??
  11. Silverrabbit2
    Thanks for your comment. I find that the machine's performance in the horizontal position is only as good as the table is stable. The machine is not operated in the vertical position, but that does propose an intersting concept.
    Since my table it is based on an X-torsion wooden frame of plywood & pine, it has reasonable rigidy. I could not afford an aluminum or steel table at this time. There are also thermal expansion issues with the metal types. For now, I'm dealing with the aluminum OX on a wood table -- 2 differently thermal materials!.
    The machine is stored & operated inside my shop which has HVAC & is keep at 78F. I have no issues with alignment or repeatability to within +/- .003". I was able to tram the new 2hp router head to .001" in the Y-axis. The X, not so good. I noticed if I touched the OX framework anywhere that I could deflet the reading by .001. More serious force on the gantry pushed it as high as .005". The OX design is very nice but could be stiffened a bit in the gantry.
    My overall diagonal set up (the squareness of the OX framework was to .001" using the inside micrometer set that I had. Regardless, most work that I do on this size machine is fine with these tolerances up toan order of magnitude larger (10X), say .010".
    Daniel Harbin likes this.
  12. Silverrabbit2
    Thanks for your question. I have not machined any aluminum yet but it should be fine depending on the accuracy that you require in the finished product. If you look at the detailed post to the previous comments, you will see that I expect an overall tolerance about +/- .010, that is 20 mils total.
    The performance in any material is a combination of frame stiffness, motor horsepower, motor shaft runout, tooling runout & quality of the cutting tool. Then it is all about finding the sweet spot of feedrate & rpm for that tool. The hold down method & sufficiency is also very important link to the end result. Onsrud has a good info bulletin on this as does precision bits (Think & tinker). Vortex also has info.
    As for CAD plans, I did not start this project in CAD. I built the OX/Ooznest from their parts, then a table out of wood, then bolted on the table to the Husky, then the OX to the table.
    .Best wishes.
