OneZ i3
Discussion in '3D printers' started by Keith Davis, Apr 17, 2016.
  1. Christian Setla
    Christian Setla Journeyman
    Ooh ooh ooh..... Never mind, I'm almost there with the OneZ! Got my bearings today, so it's going to be back at it again... Hopefully no more stumbling blocks. I'm interested in the TrueUP, non the less, and look forward to seeing the latest iteration, and a parts kit might be a good way to help guys outside the US, such as myself, not to mention *anyone* wanting to build their own and that do not have access to a printer at the moment.
    I realize, once I have my OneZ running, it should be easy enough to print most, if not all the parts I need for the TrueUP. The nylon bits might be a challenge due to the cost/availability of that particular filament and if one has no need to print nylon otherwise, perhaps a nylon parts kit might be something to think of as well. I know I would be interested in that for sure, and those specific bits for the extruder might be hard to find as well.
    I'm finding that things from China are taking a good 6 to 8 weeks to arrive at my address, whereas before it was only 3 to 4 weeks. This really does try ones patience.
    Regards
    Christian
  2. Keith Davis
    Keith Davis Master
    Resolution is just a matter of belts, pulleys and motors - if the framing and mounting is square, level and solid (which a OneZ is).
    X & Y resolution is 0.0125mm if 20T pulley, GT2 belts and 200 step motors at 1/16 is used.
    Z axis on a OneZ moves 1mm per motor rotation, so X resolution is 0.005 per full step w/200 step motor.
  3. Keith Davis
    Keith Davis Master
    The changes I plan for TrueUp are to split the 4 large pieces so they can be printed on an 8x8 bed. The Nylon bushings - well - uhhh - well -- Nylon is not necessary. I'm using.selling Nylon just because "self-lubricating Nylon" sounds good marketing-wise, whereas "Don't fret about the PLA bushings, Z axis movement over the life of a printer is negligible and PLA bushings will not wear" doesn't sell as well. But it's the truth. My prototype which has over 1500 hours uses PLA bushings and is as tight as hour one. For a DIYer, I recommend PLA.
    Keep in mind Chinese New Years is Jan 27 in 2017. That usually means a two to three week pause in shipments from China as half of the export workforce goes home for two weeks.
  4. Christian Setla
    Ahh... the "ol" marketing ploy, eh? <grin>
    I guess I had better finish up this OneZ and get to printing stuff as I have lots to learn.
    Chinese New Years.... I've run into that one before.... And it's a LOOONG New Years too.
    The chopping up of the large pieces will make it printable on a regular printer. That's what I was thinking of doing when I make the TrueUP, looks like you are going to save me the work! I was going to modify it to a 300 x 300 build surface, but I see there are 200 x 300 heated build plates available and it's a reasonable compromise, so I was thinking I can just stretch the X axis to accommodate the longer build plate and the Y axis could stay the same. The again, extending the Y axis might be cheaper?!?! Only need longer rails and a longer belt? Hmmmm.....
  5. Keith Davis
    Keith Davis Master
    Actually that's just what I did. Replaced the Y frame piece with one 100mm longer, longer belt and a 200x300 mirror, and adjust te firmware for longer Y. For those pieces I just don't use a heated bed - I used heated bed for PLA just for drying the Aquanet quickly, so on this printer it ties up a hair dryer. I'm actually wanting to change so I can free-up this printer for going back to other prints.
    I really want to get to China sometime just so I can party for 2 weeks for New Years. I haven't partied like that for decades :D
  6. Christian Setla
    That settles it.... 100mm more Y on the next build! As for the heated bed.... I too will probably be sticking with PLA for most stuff, so perhaps a heated bed can be left for later, if needed. I do know I see a need for more than 8" now and then.
    Pity I can't get Aquanet in Canada, except through Amazon.ca, and it's way to costly that way. I'm hoping glue stick or woodworking glue will be good enough. There's always buildtak and those sorts of things I suppose.
    As for parties in China.... Ugh... I can't even stay awake until midnight on New Years Eve!
  7. Robert Kirkpatrick
    Robert Kirkpatrick Journeyman
    On my other laser build I have been quoted around 100usd plus shipping for the 3d printed parts with a 100% infill. Could someone please quote for the printed parts on this build? Many thanks in advance
  8. Robert Kirkpatrick
    @Keith Davis
    Thanks again. I want to go ahead with this now so is the BOM which is on the build page up-to-date? Or should I wait for your kit next week? Will the kit include everything I need? Printed parts included? Thanks
    #128 Robert Kirkpatrick, Jan 4, 2017
  9. Keith Davis
    Keith Davis Master
    Sorry for the delay Robert, We've had a snap blizzard here today and I've spent the better part of the day on a backhoe pulling people out of snow drifts.
    I think I've answered this over at TrueUP Glide
    MaryD likes this.
  10. Christian Setla
    So, I finally get back to work as I got the bearings I needed (6 weeks from China?!?!) and the darn things are binding (6mm threaded Z rods). Look at build again... doh... I need 4 x 6mm precision washers... not listed in BOM. Considering Canada supposedly went Metric a long time ago, you'd think *any* of the local hardware stores would have Metric fastners... Nope, not only that, but the fastest way to get a set of Metric drill bits was to order a set from the UK via Ebay and this is in a Metric country, in a 3/4 Million pop. City. <groan>
    Rather than sit back and wait again, I decided to make some washers... I started with 3/16" washers and super glued them to a piece of 2 x 4, drilled them carefully with a 6.5mm drill in a hand drill and then ground them flat by hand on a diamond hone I have. I have a pen turning mandrel that measures 6.2 mm so I can always stack, clamp and either file them down on my woodworking lathe or sand them down on my belt sander if need be to make them smaller. I do have to say, I'm looking forward to getting this finished as the TrueUP looks like a much cleaner build.
    OK, enough feeling sorry for myself, back to work!
    I'm just thanking my lucky stars that Keith did all the hard work.... If I had to design something from scratch.... I'd still be sharpening my pencil.
    Chris
    Robert Kirkpatrick likes this.
  11. Keith Davis
    Keith Davis Master
    I of course live in a country where proposing going metric would kill a politician's career and launch protest marches in the streets. BUT, in this small burg, there are two different farm supply stores that carry pretty full lines of metric screws, washers, etc. Why? Farmers buy machines manufactured for global market, and, break those machines regularly, and, are know as baling twine and bubble gum repair experts who aren't likely to call the Maytag repairman. If you have farm supply stores available, take a look.
  12. Robert Kirkpatrick
    What a nightmare. I can't even imagine using the imperial system. If you get stuck I don't mind sending something at cost to you, something to bear in mind I guess. Rob
  13. Christian Setla
    The only one we have is called Princess Auto. I've been there and again, it's all Imperial. I did have a machine shop supplier back when I was a gunsmith... no issues getting metric stuff there, but alas... they closed down last year. I checked another outfit and they only want company purchase invoices, no street traffic. Even the Bolt Warehouse stops at 4mm, which would have worked, but they have a $5 minimum charge.... so it only pays to go there when you want to stock up .
    Around here, bubble gum and bailing wire are considered the correct way to fix farm machinery. Grocery stores price things in KG but sell in Lbs, fuel is sold by the liter, speed limits are Km/h but fuel consumption is still quoted as MPG and of course our Gal is bigger than yours! :)
    I'm just venting.... no worries.
  14. Keith Davis
    Keith Davis Master
    BTW, those 6mm washers don't have to be metal, or perfect. The washer is actually a spacer. It's ID has to be 6mm(1/4" will do) for the 6mm screw, and the OD has to be small enough that it engages the bearing's inner race but not the outer race (12mm or 1/2"). You could use cardboard, plastic, etc. The purpose is a filler to transmit the motion of the pulley through to the acorn nut so they can press towards each other on the screw to press the bearings into the pillow block - without touching the outer race of the bearing. They of course need to be flush so the pulley and acorn nut engages them flushly. Height is unimportant, 1, 2, 3, 4mm. Originally I didn't have any the day I was prototyping and I just printer off a spacer (baling wire and gum trick).
  15. Christian Setla
    Yes, I figured *anything* would work to free up the bearings so my crude washers I made worked just fine. I was going to use a thin hard plastic sheet but the drill kind of tore it up so I figured I'd try making steel ones.
    Evening was set aside for something else so I'll continue on Sunday... hopefully, no more delays... I really want to get this printer up and running.
  16. Christian Setla
    Robert, I lived in Norway back in the early 70s and worked in a BLMC (British Leyland Motor Cars for the NA crowd) shop. The nightmare was when South Africa began assembling Austin cars made from UK sub assemblies. The UK sub assemblies, at that time, were put together with Imperial fastners... South Africa was metric, so they used all metric fastners to put the cars together. We needed two complete kits of tools to work on those cars, and at times you needed an intuition of what standard the bolts were. I also quickly figured out where I could use *either* wrench/socket... 13mm or 1/2 was the most common.
    Thanks for the offer of shipping an item. UK to Canada post is rather quick for some reason... Usually 5 to 7 days. It's as fast or faster than mail from the USA, depending on what state it's coming from.
    Regards
    Christian
  17. jel111
    jel111 New
    So I am debating making this printer I like the look and you seem very attentive which is awesome. What kit is this and which are the latest files. I read a bunch of the posts but jumped to the end and noticed you are on could you post the link again for me please'
  18. Keith Davis
    Keith Davis Master
    All the links are on the bottom of the build page
    OneZ i3
    Christian Setla likes this.
  19. nspence
    nspence New
    Hey Keith, I've decided to build your OneZ i3! Two minor things I noticed while ordering parts:
    1. Unless I've missed it, I don't see a the belts for the X and Y Axis in the BOM.
    2. On the BOM the quantity of the GT2 20 tooth pulleys (5 and 6mm) is reversed from the quantities on the PDF
    Thanks!
  20. Keith Davis
    Keith Davis Master
    Yes, the X & Y belts are not closed loop belts, so I did not list them. Figure a 1 meter should do it. Usually sold as more than just 1 meter.
    Only 2 GT2 20 tooth pulley 6mm are needed for the 6mm Z screws. I actually just drill out two 5mm ones to 6mm. Inow fixed that to be correct on PDF.
  21. Saint Billy
    Saint Billy Journeyman
    Hi, I like the look and ability of the OneZ i3 and will probably build it when I have finished building the Ox cnc. Any rough idea's of costings?, hopefully I don't have to lie to much to the other half.
  22. Keith Davis
    Keith Davis Master
    The BOM is at $306.
    Saint Billy likes this.
  23. Saint Billy
    Thanks Keith, that's excellent.
  24. Robert Kirkpatrick
    BOM however does not include cost for 3d printed parts needed
  25. Saint Billy
    Oh ok, not too much of a problem but I wiil have to source someone here in the UK to make the parts for me.
  26. Robert Kirkpatrick
    Look for Printverical's hub on 3d hubs. His prices are the cheapest on there as he's just starting up. My build cost for the trueup glide are £405. Build costs are more in the UK mainly because we don't have openbuilds parts store :( gonna be worth it though!
  27. Saint Billy
    Thanks for the info, thats a great help.
  28. seve030608
    seve030608 Well-Known
    ITS ALIVE!!!! Still needs some tweaking and learning on my part ! Support from Keith has been 100%! Couldn't have gotten this far without his help!
  29. Eclectic Hobbyist
    Eclectic Hobbyist Well-Known
    Hello! I just wanted to say that I love the design. However, I won't be printing the whole thing. I actually downloaded and modified your extruder so that it is capable of handling a BL Touch. When I've finalized it, I'll be happy to share it with you :) But thanks for doing the heavy lifting already, it was a breeze to add the support for one into the main body of the extruder.
  30. Keith Davis
    Keith Davis Master
    When you get pics and specs post it all right here on this forum so everybody can see it - and USE it. Looking forward to it!
  • About Us
  • Like us on Facebook
    Donate to FairShare!
