Need help with antibacklash nut block
Discussion in 'General Talk' started by Justin Christensen, Dec 18, 2016.
  1. Justin Christensen
    is there a video or other thread showing how to properly setup the antibacklash nut?
    I'm not sure how tight to set the set screw. Do you want it to right where it is touching or add some tension to it. Thanks in advance
  2. nka
    nka New
    Did you find the answer ?
    edit: Found this finally :
    To use the the Anti-Backlash Nut Block - Turn the set screw just enough to take out any play in the Nut Block. Then screw the lock nut on the top of the set screw to lock the set screw in place.
  3. GrayUK
    nka.
    Thanks for going to the trouble of finding the information and replying to Justin's question, and it was a good question and answer. :thumbsup::thumbsup:
    However, I was wondering if you happened to notice the date it was posted? :rolleyes:
    I sure hope he found the answer some time ago. (Actually, checked his history and he has made himself a couple of machines since then.) :D
    Many Thanks though. :thumbsup::thumbsup:
  4. nka
    nka New
    yeah I saw the date, but at first, I wanted him to help me... then I just posted the answer in case of someone else asking the same question and find this thread !
  5. GrayUK
    Where did you find that answer?
  6. nka
    nka New
  7. Biggles
    Biggles New
    Thanks for that, I was asking the same question and just found your answer now ;)
    Always remember to check our Youtube channel too for tutorials
    Giarc, Mark Carew and GrayUK like this.
