My C Beam - NEMA 17 - GRBL- Arduino project
Discussion in 'CNC Mills/Routers' started by Huub65, May 24, 2017.
  1. Huub65
    Huub65 Well-Known
    Huub65 published a new build:
  2. Kevon Ritter
    Kevon Ritter Veteran
    I'm curious as to why you strayed from the 23 that it was specifically designed for? Unless you plan on cutting foam, you're really not going to save any weight. Equivalent torque from a 17 would actually result in a longer can than a 23 as well.
  3. Huub65
    Huub65 Well-Known
    Hi Kevon,
    Thanks for the reply.
    No specific reason , its Just because I have the 17s laying around here.
    Weight is no issue.
    I like to experiment, even if this means thats ik must create my endplates for the 17s.
    If it turns out not to work I will upgrade to the 23s.
    Building is fun, even if there are incertaincies I think.
    #3 Huub65, May 26, 2017
    Kevon Ritter likes this.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
