Mendal Max - a part of this, a part of that.
Discussion in '3D printers' started by stargeezer, Feb 21, 2015.
  1. stargeezer
    stargeezer Veteran
    stargeezer published a new build:
  2. shali85
    shali85 New
    Cute little thing. Watching.
  3. DiggerJ
    DiggerJ Master
    Could you describe the "EX2" enhancements? I am building a beefier MM1.5 right now
  4. stargeezer
    stargeezer Veteran
    The additional 10mm rod on each side of the z axis is a tremendous advantage. The upper brackets are muck beefier which helps keep things square and makes the entire frame stronger. I also used 10mm rods in the "y" axis, with four linear bearings. The carriage ends are twice as strong as the more typical ends too.
    check out the carriage end and the 4 bearings in the end. It's super strong.
    The pair of 5208zz bearings on the upper z axis really helps deal with z wobble.
    I hope this helps.
  5. DiggerJ
    DiggerJ Master
    All makes sense. Can you share the .stl's for the enhancements? I like the idea of stronger and less wobble.
  6. stargeezer
    stargeezer Veteran
    Hi Diggerj - check out this link on thingiverse. It's where I got most of my files from to make this. http://www.thingiverse.com/thing:466241
    The y axis I used was a wider version but I can't find the link for right now. It's almost 8 inches between the rods. It also came from thingiverse.
    Enjoy!
  7. DiggerJ
    DiggerJ Master
    Thanks much. Now to see if I have enough pink left....or I'll have to spend more green.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
