McRouter 3 Axis CNC
Discussion in 'CNC Mills/Routers' started by PaulS, Jul 9, 2015.
  1. PaulS
    PaulS Well-Known
    PaulS published a new build:
    Can you give us a link to the slides you are using?
  3. Joe Santarsiero
    Joe Santarsiero OB addict
  4. PaulS
    PaulS Well-Known
    The rail is part number 9867K13 from McMaster. The carriage should show up as well when you search for that item.
  5. Joe Santarsiero
    Hardened steel vrails, steel wheels, and spacers cost less...if anyone was curious.
    for 1000mm
    Ptfe slides@.11 per mm x 2 sides of the axis = $220 + 2 carriages @ 56.60 = $113+$220 = $333 for one 1000mm axis.
    #2 Ground and hardened rails go for $1.11 an inch. matching vwheel bearings for $5.50 and eccentric and concentric for both sides total $46 for 3 concentrics on top and 2 eccentric on bottom of each side.
    Total: 4000mm/25.4=157.48"...x $1.11 =$174.8+($5.50 x 10)=$230 + $46 = $276
    +333
    -276
    =57 dollar difference over the profile.
    However, for the difference in price the profile is probably a lot less of a headache in the shortrun. Just trust me! :rolleyes:
    GrayUK likes this.
  6. PaulS
    PaulS Well-Known
    I definitely agree with you. I simply went this way to reduce moving parts, simplify, and with my steep discount it was way cheaper than v wheels.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
