Looking for design ideas please....
Discussion in 'CNC Mills/Routers' started by selkov, Oct 13, 2015.
  1. selkov
    selkov New
    I have a small machinist lathe that I want to mount a router on. It will be mounted in two fixed positions on one post. No travel is needed.
    In position one the Router is mounted vertically so that the cutting action is at a right angle to the motor and uses a standard bit to cut on edge.
    Then i will need to re-position it so that i can cut threads. This cutter is shaped like a drill bit and cuts with the point.
    I have an idea on what to do but before I start I would really like a few other ideas to consider.
    So,,,,, how would you do this?
  3. Joe Santarsiero
    Joe Santarsiero OB addict
    I would use the lathe to face and thread the part. :D
