Leveling Gantry
Discussion in 'CNC Mills/Routers' started by David Brenner, Nov 19, 2014.
  1. David Brenner
  2. GrayUK
    GrayUK Master
    Hi David.
    I know you're just getting started, but a couple of ideas came to mind with regard to a levelling type machine.
    I guess you plan to have your router mounted into a sled type of affair, and being able to slide it across the the face, on the gantry rails. Good idea, just make sure those rails are substantial, against flex in either direction, particularly up and down.
    How about gantry plates at each end, with slots, allowing you slide the Gantry up and down, and therefore set the required height manually. Build a spirit level into the gantry rails.
    Really basic, but you could always motorise it later.
    I know the trouble I've had in the past with regard to level the surface of an old table top. Something like this would have made my life a whole lot easier. However, you really do need to use it frequently to make it worthwhile.
    Good Luck :thumbsup:
    Keep us posted on the build.
    Gray
  3. David Brenner
    Thanks Gray. I appreciate your input.
    You are correct that I'll be mounting the router on a sled that will sit in between the horizontal rails. I have those designed as two 20X60 v-slot. I am thinking that will be substantial enough to handle the weight of the router over the width of 48 inches without flexing.
    I eventually want to enable the gantry to be able to go up and down as you described. Do you think that replacing the corner bracing where the gantry connects to the vertical posts with wheels will render the joint unworkable?
    I like the idea of adding the level. I hadn't thought of that.
  4. GrayUK
    GrayUK Master
    Well to keep it simple and positive I was initially thinking of creating an oblong frame with the aluminium, X axis, joined with a piece at each end, similar to what you already have designed. Short enough to fall between a pair of gantry plates similar to what you see on our Forum. And yes to could motorise it easily like that.
    However, your rollers on your front to back lengths, ie, the Y axis, should each support a plate, its' height being, say the depth of your router plus whatever height you have in mind generally to level at, say up to 4" or 100mm depth.
    Fit two bolts, long enough to go through each of the aluminium pieces across the ends of the X axis, and through the slotted plate with tightening knobs and a couple of washers on the ends.
    To adjust the height just loosen of the knob, slide up or down the slot to the required height, at each side.
    There you go. If that makes any sense. :confused:
    Make sure you leave the ends open, and accessible, to be able to consider using it to level tables and doors, and many other applications.
    I just read on a Woodworking Magazine Site, that a guy has made this incredible table top, but can't figure out how to level it off, it being sooo long.
    You could make a much fancier one, and no doubt there will suggestions forthcoming on that point, but start simple, see if it works, and progress from there. :thumbsup:
    It has Great potential.
    Go for it!
    Gray
  5. jcoats
    jcoats New
    David,
    http://www.thewoodwhisperer.com/videos/flattening-workbenches-and-wide-boards-with-a-router/
    Marc (the Wood Whisperer) has a great and simple (if not tedious) technique for flattening a workbench with a router and a few chunks of wood and some wire. Do you need to it to be level or flat. Flat with make it 'relatively level' but not necessarily 'level with the horizon'. I hope that makes sense.
    There are other great descriptions of 'how to' do this. If you want to do it with hand planes, find out about 'winding sticks' and how to make and use them. They are used to detect how 'flat' a board may or may not be related to a line on one end. Charles Schwarz (formerly of Popular Woodworking, currently with Lost Art Press) has some good articles that can be found online, but there are others too.
    Both of these techniques will let you get a workbench or lumber pretty flat with relative ease. You still must deal with wood movement due to temperature and humidity.
    Just a suggestion!
    Disclaimer: I am not affiliated with Marc or Charles, but I do enjoy the content they provide.
  • About Us
  • Like us on Facebook
    Donate to FairShare!
