Lead screw printer
Discussion in '3D printers' started by kylesmth, Jan 19, 2017.
  1. kylesmth
    kylesmth Well-Known
  2. Jeffrey Drake
    Jeffrey Drake Well-Known
    Do you happen to have a video of it moving? I am very curious how fast that thing can go.
  3. kylesmth
    kylesmth Well-Known
    It's definitely not as fast as a belt driven type but the quality difference is pretty nice. I've been running it around 70 mm per second with great results. I'll definitely get some video up in the next couple of days.
    snokid and Jeffrey Drake like this.
  4. kylesmth
    kylesmth Well-Known
    Sorry I was having some issues, I got a bit of a better video now. I'm working on getting a better camera this had to be filmed on my iphone.
    jamesdjadams likes this.
  5. Jeffrey Drake
    Interesting choice of base material. I was planning on a heated bed, so wood is out.
  6. evilc66
    evilc66 Master
    Nice. Looks very similar in setup to my C-Beam based printer.
    kylesmth likes this.
  7. kylesmth
    kylesmth Well-Known
    i'm wondering if you have any issues printing smaller circles? it seems like it can keep up with everything else at a decent speed but I need to work on some settings to get it printing better with the smaller circles. What kind of jerk and acceleration settings are you working with?
  8. evilc66
    evilc66 Master
    How small of a circle are we talking about?
    Jerk settings (junction deviation in Smoothieware) I left at the default for Smoothieware. I did have to lower the acceleration a bit from the default, but I can't remember off the top of my head what I ended up changing it to. I'm direct drive with a Titan extruder and a thin profile NEMA17 motor, so my X-axis carriage is fairly light, but a little heavier than yours. It was still enough weight to get it to skip steps under fast acceleration (3000mm/s).
  9. kylesmth
    kylesmth Well-Known
    Small holes as in M5 and M3. I will try to drop the acceleration a bit and see what kind of difference I get.
  10. evilc66
    evilc66 Master
    Dropping the acceleration might help, but it's also dependent on what the actual problem is that you are seeing with the holes. It may actually be a slicer issue and you just need to drop the speed for external walls.
  11. evilc66
    evilc66 Master
    I guess I haven't made enough parts with holes to comment either way on that particular issue.
    I know in Slic3r you can set the extrusion width for external perimeters. Have you checked that setting (or similar to it if you aren't using Slic3r)?
  12. kylesmth
    kylesmth Well-Known
    I'm using simplify 3d, I'll double check all of my settings. Im going to be doing some more testing today so I'll report back here with my results.
  13. kylesmth
    kylesmth Well-Known
    I've pretty much dialed everthing in now, the setting I'm using seem to be working pretty well. If anyone wants I could post my config.g here or my slicer settings
  14. evilc66
    evilc66 Master
    In the Slic3r options, go to the Print Settings tab, and click on Advanced on the left. That will give you the options for adjusting the extrusion rate for different features.
