Jim's C-Beam Machine Build
Discussion in 'CNC Mills/Routers' started by Jim_H, Aug 7, 2016.
  1. Jim_H
    Jim_H New
    Jim_H published a new build:
    Joe Santarsiero likes this.
  2. MaryD
    MaryD OpenBuilds Team
    Look forward to the pictures @Jim_H !
  3. Jim_H
    Jim_H New
    Thanks, MaryD! I've hit a bit of a snag in my calibration of the machine, though. I can't seem to get the frame square. Every surface I've tried to build it on is off just enough that when I get the machine put together, things are off by about an 1/8" over the run of the axis'. I've rebuilt the frame three times now. :) I'm going to have a friend help me get a flatter work surface built and try again. Overall, I'm enjoying the build and the problem solving challenges it's supplying, though.
    MaryD likes this.
  4. Evgeniy
    Evgeniy New
    You used to press the shift in the center of the circle. Appropriate to use to create a form of clamping spiral of Archimedes.
    MaryD likes this.
